Gold Member Username: NydasPost Number: 3398 Registered: Jun-06 | LK: Learn from your mistakes. On August 16, 2007 - 01:56 pm you post new keys quickly. At 3.12 pm Khopdi pointed out to you that they are not good. At 3.29 pm, Khopdi said '" never mind. He had discovered that the beginning 20 in Key 01 should be 63 and not 20. This conforms to he bit inversions I have pointed out. At 04:20 pm you tried to give an explanation. You did not know that the FC in Key 00 should have been BF for a reason '" the same as I have pointed out in this thread FC had to be manually changed to BF, as per table I have posted here. Then the big ones came out with the correction, so now people have not problem with those receivers, but the Pansat 2500 and Fortec ultra (294T BIN) has not had a correction yet. By the time BL comes out with a 295 BIN, or soon after that there will be a slight shift in the key morphing ECM. If I am around and I can spot the key inversion pattern, I will post it and alert people. My current alert applies mainly to 294 and 294T BINs. Those who are reading this and familiar with binary representation of hex numbers, can do the same easily. The main thing to remember is that it is not a simple arithmetic of +-, but inversion of a bit '" a particular binary bit is changed form 0 to 1 or 1 to 0. Betfor 16th August it was the top bit only (bit 7) of the first number in both keys '" hence somebody posted +- 8 correction. Currently since 16th August, it is Bits 6,1 and 0 and hence the complicated table above. This correction is already accounted for in the 17th August BINs of Viewsat family and most of the Pansats except 2500A, clones and Fortec. **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- LK Platinum Member Username: Lklives Post Number: 11058 Registered: Jan-06 Posted on Thursday, August 16, 2007 - 01:56 pm: yes new keys a few minutes ago...be patient while keys autoroll (1 min-1 hour)...usually 2-10 minutes.. Dish Network (0101) (Last Update: Thu. Aug 16, 2007 1:24 PM EST) Key 00/86: FC 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 New Active Key 01/96: 20 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D Bell ExpressVu (0901) ''''''''''''. **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- Khopdi Bronze Member Username: Khopdi Post Number: 51 Registered: Apr-07 Posted on Thursday, August 16, 2007 - 03:12 pm: LK - Please varify keys. The links listed below all have same keys. The keys you have posted do not match the links. Please confirm correct keys. [link removed] [link removed] [link removed] **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- Khopdi Bronze Member Username: KhopdiPost Number: 52 Registered: Apr-07Posted on Thursday, August 16, 2007 - 03:29 pm: LK - Nevermind. I got it. The correct keys are as follows: 00:FC 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 New Active 01:63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D 01 begains with 63, not 20. **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- **-- LK Platinum Member Username: LklivesPost Number: 11069 Registered: Jan-06Posted on Thursday, August 16, 2007 - 04:20 pm: Listen people...DN changed the keys (1:24pm EST) to a B1 EMM (intended to disable all receivers using autoroll) earlier that I posted above... but then quickly reverted back to the old keys from early this morn and late last nite, cause it must have affected some subs...but now DN has just changed again...and so has Bev... Dishnet 0101 ..(Last Update: Thu. Aug 16, 2007 4:00 PM EST) 86: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 Active 96: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D |
Platinum Member Username: LklivesPost Number: 11184 Registered: Jan-06 | LMAO...what mumble jumble...If U could comprehend!...what U posted above is exactly right about DN keys , and reverting back to the old keys for a very quick time...and then again changing to new DN keys also immediately again..my keys posted were always correct at the time of my postings! BTW FU*CK U nalin...who cares what BS and BOGUS crap U post...its all wrong and ignorant!...only newbies who don't know U will listen to U, cause all the experienced peeps here and at other sites don't like or want U around...they know U do NOT know anything about FTA except your cheap 2500 clone...and even then U make a simple key input into something complicated! |
Platinum Member Username: LklivesPost Number: 11186 Registered: Jan-06 | nalin...get a job...U are here 24/7...I'm retired!...but U are a non retiree and a non working immigrant ,, sucking the welfare system, who is here 24/7...instead of working! I notice U are here in the mornings, afternoons, evenings, and late nights on a DAILY basis...EVERY DAY!...so don't even give me another lie about U having ANY type of employment! |
Gold Member Username: NydasPost Number: 3404 Registered: Jun-06 | LK: YOU are here in the forum 25 hours of the day, 8 days of the week, 32 days of the month and 367 days of the year. EVERYBODY knows that. |
Silver Member Username: Destine0429Quebec Canada Post Number: 249 Registered: Dec-06 | I don't understand what happened between you two. But this forum is supposed to be for helping people to learn how to do the Satellites. Yet you are here, constantly bickering at one another. And quite frankly, it's getting alittle old and starting to be tasteless now. The only reason I even both to read these, are the fact that I am curious as to how low everyone will stoop to just to get more postings under their belts and to get attention. You two don't have to like each other, but being respectful is supposed to be one of the easiest things in the world. Yet, here we are, every so often, trying to gut each others insides out.Grow up alittle ok? And this is coming from someone who is only 23 years old |
Platinum Member Username: LklivesPost Number: 11200 Registered: Jan-06 | I don't like being disrepected by a immigrant newbie who has run off all the good veteran peeps here...slo_hand2, helter skelter, sparky, Mc Sunny, PRFRMNJ, boots, James Millard etc.....and now she's trying to push me out!...and I've been here over 4 years!..and experienced in DSS over 10 years! in fact Julie, U should be a little more proactive to rid nalin from here...cause she has destroyed many newbies receivers with her BOGUS posts!...and pushed AWAY much experience from Ecoustics!....U better decide what U want, either nalin or experienced testers...we all want peace, but its NOT possible with nalin here! Soon there may be NO experienced testers here, if we all walk away because of her...cause thats what nalin wants,and U seem to think thats OK, as long as U have free TV...I'm disappointed in you!...U think I like this crap?...especially when I read posts from U, with a kiddie lecture...maybe U don't realize the severity of this...would U like somebody STALKING U CONSTANTLY and trying to move U out of your home?...there is NO middle road here...U must choose or this site will be 100% non informative, if nalin continues and the veteran peeps here continue to leave! |
Bronze Member Username: Redwater71Post Number: 15 Registered: Sep-06 | What there is actual information on this forum ? I thought this was a joke ... LK...no offense, this is not a great place to get info. It's great for a laugh though. Register to a real forum where actual people know what they are talking about. Not waste time bi.tching and moaning on other people (who don't give a flying shi.t about who you are) but what valid info you give. If you're unhappy .. bend over and do it yourself ! |
Silver Member Username: Destine0429Quebec Canada Post Number: 252 Registered: Dec-06 | LK, I am sorry if you think I am lecturing you. It was not my intention at all. I was just saying, that from the looks of things, she was the one who started all this. And it's getting rather dull and annoying that it keeps going on. I understand that she is pissing you off, along with everyone else. No I do not want to be sitting here stuck with Nalin all by myself. I'd have nightmares for years and have to call a psychiatrist. There must be a way to block her off this site. Even if she keeps getting new IDs. Block her IP address. I want this site to continue to run. This site has taught me alot in the past year and a half. And I"m very thankful to everyone on here who has helped me. I even noticed alot of the usual names have disappeared. And that sucks. One person should not piss people off that much. But it seems to be working. She knows no one here likes her, and wishes she would take a long walk off a short bridge, but she isn't leaving. And from the looks of things, the Admins aren't doing much to stop this either. Even though they sure block people for much less. Which is ridiculous. I hope no one else leaves. I'm not smart enough to help everyone with their boxes, and it would surely take more than 1 person to tell everyone that Nalins bins, keys, and whatever are useless. |
Bronze Member Username: Omen_2Post Number: 28 Registered: Feb-07 | Who do you believe your eyes or LK? LK Registered January 06, 2006 as of now Total Posts 11,194 and counting. Nalin Nyda Registered June 03,2006 five months after LK as of now Total Posts 3,407 could someone here tell us who spents more time on this forum? |
Bronze Member Username: Bill038Post Number: 89 Registered: Sep-06 | So what? |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 9369 Registered: Jun-06 | To me that's called contributing. If all you do is read and not post who are you helping? It's here for the taking and the price is right, why bite the hands that feed you? Just my $.02. |
Bronze Member Username: Omen_2Post Number: 32 Registered: Feb-07 | Nobody was talking to you f@gget Bill or did I make a mistake you are LK. |
Bronze Member Username: Bill038Post Number: 90 Registered: Sep-06 | Think what you want butchy boy. Does your MaMa know your playing with the computer? |
Silver Member Username: AmexPost Number: 370 Registered: Nov-06 | . |
Silver Member Username: Destine0429Quebec Canada Post Number: 255 Registered: Dec-06 | Lol Mr.Bill Unfortunately hon, I think you need to get a new picture though...That one is on it's way to being over used. |
Bronze Member Username: Omen_2Post Number: 40 Registered: Feb-07 | Yes, Bill Vickers or who every you are she would also like to know why are you here |
Silver Member Username: AmexPost Number: 381 Registered: Nov-06 | @ Julie White lol, Julie.......but don't you think "she" looks better in pink ?................... . |
Silver Member Username: AmexPost Number: 382 Registered: Nov-06 | . |
Silver Member Username: AmexPost Number: 386 Registered: Nov-06 | . |
Bronze Member Username: Omen_2Post Number: 46 Registered: Feb-07 | Mr Bill when you find no action what you are holding in you hand in the picture above is it fair to say that you stick it up your ss |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2788 Registered: Nov-06 | |
Bronze Member Username: Omen_2Post Number: 53 Registered: Feb-07 | Pusssy if I could only truly get my hands on you then you could see who will fucck who stupid motherfuccker |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2801 Registered: Nov-06 | You need help ! |
Bronze Member Username: Omen_2Post Number: 57 Registered: Feb-07 | I wouldn't bet on that. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2802 Registered: Nov-06 | I would! What makes you think you can fight your way out of the faggs bathroom room? You think your a tough guy, or a bad azz? |
Bronze Member Username: Bill038Post Number: 93 Registered: Sep-06 | butchy boy,are you nylin's butt boy? If she wants to know what I'm doing here, let her/him/it ask. She don't need your for a mouth piece, unless you like the job. |
