my friend bought a 2500 clone and he doesnt know wat to do. i have never used a clone, I know that bl doesnt make the bins chancysand or watever makes them.
So im guessing that i dont need to do the b-75 upgrade. is that right?
B75 boot upgrade is ONLY for Pansat 2700 CLONES...NOT 2500 Clones!
with 2500 clones u simply just upload the clone 2500 bins ending in "T" , by chancysand....these are MODIFIED genuine 2500 bins from BL...U cannot use GENUINE bins without the "T" for the 2500 CLONES...there is NO working autoroll bin now for the 2500 clones...so U must shut OFF the autoroll options, and manually input the latest keys EVERY time there is a new key change, UNTIL a newer bin is released which probably will be awhile......the latest 2500 clone bin is 294T....good luck!
