can anyone give me some advice for the future?? its seems ive blown my amp on my 1st install,doh! the inline fuse blew the other day and i replaced it and then the amp wouldnt work no power or sound although the fan came on.ive just looked inside the amp and some of the components are fried especailly around the ground wire inside.after reading through some threads ive found that the ground is usually the problem with installs and looking at mine i can see that there is paint on the connection i had.can a bad ground blow an amp?
