Bronze Member Username: Santa_fePost Number: 47 Registered: Jul-07 | Hey guys everytime i play a certain bass test my in line fuse will occasionally blow...now i just changed what brand of fuses i was useing and now that i look at them close they look kinda cheap...the fuses are 20A so my question is are some brands of fuses sturdier then other like even tho there both 20a can the good brand handle more current or is there another problem here??? |
Gold Member Username: LoudonPost Number: 1521 Registered: Jun-04 | get an ANL fuse block and fuse ... they go from 100 to upwards of 500 A ... they will hold up alot better then an agu fuse ... which will give you confidence in playing that certain bass tune ... |
Bronze Member Username: Santa_fePost Number: 48 Registered: Jul-07 | but if i put say a 25A fuse in and it takes a 20a wont that mess with things???? If not where can i get one of these fuese and fuse blaocks??! |
Gold Member Username: LoudonPost Number: 1522 Registered: Jun-04 | are u talking about the fuses for your vehicle or are u talkign about the fuse for ur audio system? |
Bronze Member Username: Santa_fePost Number: 50 Registered: Jul-07 | audio system |
Gold Member Username: LoudonPost Number: 1523 Registered: Jun-04 | www.knukonceptz.com |
