Silver Member Username: Volfenhagking1600SSD Wangin, Shawano, Wis... USA Post Number: 893 Registered: Oct-06 | Are there any advantages of using aeroports instead of just a regular port? |
Silver Member Username: Bjfish11Garden Plain, KS USA Post Number: 262 Registered: Dec-06 | The main advantage is that you can easily adjust the tuning if you choose to do so. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4310 Registered: Jul-06 | "The main advantage is that you can easily adjust the tuning if you choose to do so." Yep.It would sure come in handy if you wanted to tune your box high to hit a number and then you could tune it low for daily driving,it's very convenient. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11999 Registered: Jul-05 | ^^^yep thats i use them mainly for ..... |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4318 Registered: Jul-06 | However,aero ports can be costly. |
Silver Member Username: Theweasel2 12 FI SSD, Colorado U.S. of A Post Number: 980 Registered: Mar-06 | they also don't take up as much room as a slot port. they're only like 13 bucks a piece for 4" ports |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4333 Registered: Jul-06 | "they also don't take up as much room as a slot port. they're only like 13 bucks a piece for 4" ports" Have you ever seen a f@rt box with external aero ports? |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 3974 Registered: Apr-06 | f\/ck aeroports! |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3320 Registered: Jan-06 | ^^^^ His box sucked bad! <=====8 Here is what a good external aero looks like... Polo. |
Gold Member Username: DrivingrecklessDD 9515f, 148.2 db Mov... Post Number: 3981 Registered: Apr-06 | eh polo.... its time you get off potts nutz and learn to build your own boxes :-\ |
Silver Member Username: Theweasel2 12 FI SSD, Colorado U.S. of A Post Number: 981 Registered: Mar-06 | if you put the ports on the inside it takes up less room |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4337 Registered: Jul-06 | "if you put the ports on the inside it takes up less room" Lol...please stop Ryan.You're making yourself look like a noob.There's reasons that box is designed like that. |
Silver Member Username: Theweasel2 12 FI SSD, Colorado U.S. of A Post Number: 982 Registered: Mar-06 | i know there are reasons but you can still build a box with the aeroports on the inside and THAT has less port displacement therefore it takes up less room. i don't see what the arguement here is. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4338 Registered: Jul-06 | " i don't see what the arguement here is." There isn't one. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3322 Registered: Jan-06 | What has less port displacement? A slot takes up less room if I am not mistaken. Putting aeros inside actually causes internal turbulance and will hurt spl but there is nobody saying you can't do it. Polo..;) |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3323 Registered: Jan-06 | "eh polo.... its time you get off potts nutz and learn to build your own boxes :-\" That was the first box he built for me. You really need to stop hating! I can't help if I can afford to have someone else build my boxes instead of pretending that I can build my own. I never said I had skillz in woodworking but I do know how to tweak the sh!t out of my setup, probably why I have gone through less and still come out with more...Polo. ;) |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 4340 Registered: Jul-06 | Tell those haters Polo.I bet that setup slams.These guys don't understand that some people don't have the shop or time to build their own. |
Silver Member Username: Bjfish11Garden Plain, KS USA Post Number: 265 Registered: Dec-06 | I see what Ryan is saying. Given the same port area and port length between an aero port and a slot port, the aero port will have less port displacement. IE- it will take up less volume in the box. This is because the "walls" of the port are thinner. Basically a aero is ~1/8" thick vs. 3/4" of a slot port. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 12007 Registered: Jul-05 | ^^^100% right ! ...... |
Silver Member Username: Theweasel2 12 FI SSD, Colorado U.S. of A Post Number: 983 Registered: Mar-06 | thank you |
