Experimental 2500-2700 mod
Username: Runnerguy
Pluto
Post Number: 529
Any body try this yet?? It came up a SatJunkie today.
"Experimental" 'loadable' 2500-2700 mod
Experimental- USE AT YOUR OWN RISK
You should be ready & prepared to jtag!
This was posted on another site by jvvh5897;
boot b-75 modded with 2500 cmd set. Notes in zip w/ boot.
b75_2700pansat_mod_cmd.ZIP
serial loading 2500 format bin to re-write 2500's flash to modded 2700 flash image--notes in zip--but really is very experimental, can only be sure it works on pansat 2500 box. Did my best to add ultra's flash block structure, but not sure if I have it right (what I see in bin code and what I see in jkeys def file do not agree).
serial_upgrade_2500_bin.ZIP
Does do all the pansat2500 flash correctly--slow though, expect ~45 secs between boot6.0 and box re-booting with b-75 (if it works).
If you have the box converted by jtag to use the modded 2700 bin, dont' jtag back to the 2500 (unless you really, really want to test the serial load bin). The image in the 2500 bin is the same image as in the jtag file (well, the boot is different by a few bytes to make the 2500 serial loader work).
I have made no releases of a 0x70000 sized modded and compressed 2700 bin that you could load using modded boot code w/ 2500 style loader. Though you could cut the bin section from the 2.03 bin containing 2500 to 2700 flash image and use that (that is what I did my tests with--I switched back and forth between the 2.05 containing and the 2.03 containing 0x70000 sized bin sections that are between 0x80000 and 0xeffff in the resp. 1M image files).
Warning: Use at your own risk
Username: Lklives
Post Number: 11164
Many have tried this sucessfuly...and others had no luck....its NOT easy...I really see no purpose in doing this, unless U like to "tinker" around and are a TRUE TESTER, which Most FTA owners are NOT...MOST just want FREE TV......it was done originally by Jvvh for 1 reason ONLY, to prove Blacklist wrong about his trash talk about the 1 mb memory in the 2500's causing bin limitations and options...
U can ONLY use jvvh's special modded 2500-2700 conversion bins once U do this conversion...and those bins are VERY limited...yes its popular now, but this came out many months ago!
Username: Nydas
Post Number: 3391
Information on the 2500-2700 modifications can be found at:
(C/P moded from LK's post) This is excellent information according to author.
Data Viewing Sequences
[link removed] (All receivers)
Future FTA - Blacklist's Site:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
http://www.totalfta.com (VIEWSAT and All receivers)
FTA Support
www.ftaprosupport.com (all receivers)
Cut and Paste these into your browser:
REMOVE the * in links below: This site allows downloads of files without registering.
http://www.al7bar.t*k/ (All receivers)
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2771
http://www.ftabins.net/showthread.php?p=21871#post21871
Username: Nbn
Post Number: 14
I did a fortec - 2700 a few days ago. worked fast, but maybe because of the latest bin the receiver only worked for a few hours and went black screen no display. had to re jtag it and it worked again for about 10 minutes, had to rejtag and eventually load back the fortec bin. still don't know what bin should be going on the fortec after the mod, it seriously affected my TP strength
