Silver Member Username: LoudblazerEl reno, Ok Post Number: 201 Registered: Apr-07 | does anybody like these boxes? |
Platinum Member Username: James1115Use a simple... Post Number: 10165 Registered: Dec-04 | it depends on what type of BP you are referring to. They are more geared to rap. they don't have much of a frequency range, it is very narrow normally from like 50hz to 80hz but in that range they will get loud. go to www.bcae1.com and read up on different order BP enclosures. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 9266 Registered: Jun-06 | I know they are very difficult to nail in design and building. When they work they work. It can be tricky tho.... |
Platinum Member Username: James1115Use a simple... Post Number: 10171 Registered: Dec-04 | the pre fabbed BP enclosures are CR@P! the 4th order and 6th order are difficult to build but can be decent for certain types of music. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11959 Registered: Jul-05 | never heard a good sounding pre fab bandpass box .... |
Bronze Member Username: ImnothereimjustvisitingPost Number: 76 Registered: Aug-07 | ive never heard any type of good sounding prefab box |
Silver Member Username: LoudblazerEl reno, Ok Post Number: 202 Registered: Apr-07 | i got mine off ebay and put 2 12 inch volfenhags with a 250 watt hifonics. It is loud. its better than a ported 12 inch L7 with a kicker 1200. |
Platinum Member Username: James1115Use a simple... Post Number: 10214 Registered: Dec-04 | I highly doubt it! maybe it sounds good to your ears but I doubt to many would agree with that statement. |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 465 Registered: Mar-07 | theres no way it would be louder than a L7 and a 1200.1. u just pulled that out of your azz.lol |
Silver Member Username: LoudblazerEl reno, Ok Post Number: 204 Registered: Apr-07 | every single person that has heard both agrees with me. i was surprised too but im not complaining, maybe i got the best pair volfenhags ever made. |
Silver Member Username: LoudblazerEl reno, Ok Post Number: 205 Registered: Apr-07 | here is a pic, go to cardomain and search "okstud" |
Gold Member Username: CtmikeCt. Post Number: 4971 Registered: Feb-06 | where's the pic? and do a search for "okstud"? for some reason that don't sound like a search i'll be doing anytime soon, but you go ahead. and i agree, i think you made that shi_t up bout your bandpass system. |
Platinum Member Username: James1115Use a simple... Post Number: 10244 Registered: Dec-04 | agreed^ |
Gold Member Username: JkidderIA, DP RD Post Number: 1647 Registered: Nov-05 | lmfao x11. two volfs on 250 watts. haha even if u had a blown voice coil and the other one was wired to 4 ohms it would probably still be louder. get a job |
