Need help with Captive Works cw-600s Premium
Username: Ren_46
first of all I am new to the FTA scene.. I bought a cw-600s Premium and read a lot about getting it ready to bring in the sattelite channels.. I am fairly certain I loaded the correct bin (145) to the receiver.. it took it fine without any errors.. the problem I have is in setting up the receiver to pick up channels.. I followed the instructions to a "T" but keep getting "scrambled channel" sign no matter what channel I try.. I think it may be in the settings.. I pretty much left the settings as they were.. how do I know what settings to use? .. I enabled the patch through the F1 H00 code.. I may be just one step away from watching TV but I just can't figure it out.. I hope someone can help me
Username: Banej
Post Number: 250
you have to do a factory default, than scan the sattelite. turn A/R to ON. go back to the Scrambled channel message and wait for the picture.
Username: Ren_46
thanks for the reply.. I have the A/R turned on.. I am not sure what you mean by "scan the sattelite".. I know I am close to getting this going.. I am fairly certain it's in the settings.. I just don't know how to get the correct settings.. if anyone can help me out it would be greatly appreciated
Username: Brucester
Post Number: 519
goto menu on remote installation then antenna setting ther is a list of sats im on bev 91 on the list of sats it is number 41 nimiq91 hit ok on remote when you find the right sat that you have your dish pointing at then after that hit red buttion at the bottom of remote this will start scaning the sat for the channells after that hit exit on the remote you will see scrabble channell hit f1 on remote then 000 this will enable patch and watch tv hop this helps
Username: Ren_46
thanks brucester.. you are a big help!!!.. I am almost there... I have sound but no picture... I can hear what is being said on each channel but get the "scrambled channel" message no matter what channel I go to... I figured it was an A/R thing but it's been more then 30 minutes and no picture... any ideas?
Username: Yumyum
Post Number: 12
Give the box a hard reboot from the switch in the rear and you should get your picture back!
Username: Brucester
Post Number: 522
did you try turning off the box from the switch on the back of it count to 10 turn it on you will get picture and sound what bin is in your box 145
Username: Ren_46
Post Number: 8
I GOT IT!!!!!... thanks to you brucester!!!!!
