Silver Member Username: Pannu16Post Number: 419 Registered: May-06 | Ariza 700 Autoroll For Bev And Dishnetwork!! -------------------------------------------------------------------------------- temp modded files for both ariza 700 and the 700s -------------------------------------------------------------------------------- 1-Record all your settings. 2-Factory reset. 3-Load modded bin. 4-Install all settings recorded before,do a power scan only 5-Go to TV screen and let it sit it will roll Note the Quality bar will showing Zero.thats why you must do a power scan any problems with loading ...just reflash with the factory file and go back to the 295 use at your own risk for Ariza 700 goto http://www.divshare.com/download/1558350-b04 for ariza 700S goto http://www.divshare.com/download/1558336-825 P.S I also tried uploading the files but its not letting me upload the files. I have tested and its rolling baby!!! I have also uploaded these at ftaprosupport.com and al7bar dot tk ENJOY!! |
Silver Member Username: Pannu16Post Number: 420 Registered: May-06 | Its rolling fine!!! |
Silver Member Username: Ustaad_hcPost Number: 218 Registered: Oct-06 | yes i load last night working vary nice and smooth. auto roll, vary good |
New member Username: System1Toronto, Ont Canada Post Number: 1 Registered: Aug-07 | I HAVE ARIZA700,WANTED TO CHANGE THE KEYS BUT WOULD NOT GO TO "CHANGE KEYS" OPTION.ONLY WILL KEEP ASKING OLD PASSWORD AND THEN NEW PASSWORD. CAN ANYONE HELP ME WITH THIS PLEASE THANKS |
Silver Member Username: ArizaPost Number: 182 Registered: Feb-06 | I can't load this file into my receiver (700).. my receiver loads the last bin/fix but it won't load this one (current).. is there a different way to upload the new one? |
Silver Member Username: Ustaad_hcPost Number: 219 Registered: Oct-06 | its for george doug where asking old password just put there i2004 (its on your remote) then go to nagra 2 and change the keys. |
Bronze Member Username: BluebeePost Number: 16 Registered: May-06 | Ariza 700. I have done factory reset. Reloaded 295 bin, rescan all channels, entered new keys but still getting "Data is being updated...". 296 bin doesn't work at all. Any suggestions please ? |
Platinum Member Username: LklivesPost Number: 11134 Registered: Jan-06 | Ariza is a POS...and seldom has working autoroll files...and are always LAST to release them...throw it in the garbage and buy a REAL receiver, like a Viewsat or a Sonicview.. Ariza came from the Fortec family, another POS! |
Silver Member Username: Ustaad_hcPost Number: 225 Registered: Oct-06 | ariza 700 new bin 298 came yesterday. its auto roll working very nice and smooth. cheacked out if you can...... |
Bronze Member Username: BluebeePost Number: 17 Registered: May-06 | Thanks for your thoughtful insight LK. Hc, ususally I download bin files from dsstester dot com but this site is extremely slow, secondly they dont have bin 298 yet. Could you please let know about any other site. Thank you. |
Bronze Member Username: BluebeePost Number: 18 Registered: May-06 | Never mind. I got 298 bin from Thanks. |
Bronze Member Username: BluebeePost Number: 19 Registered: May-06 | I have no idea whats wrong. Loaded 298 bin, entered new keys, scanned channels, still getting "Data is being updated..." |
Bronze Member Username: NesteaPost Number: 74 Registered: Jul-06 | I want to buy Ariza Extrem. Can somebody tell me if this is good receiver and if the support is good. I want receiver that get quick fix incase of ecm or something. |
Platinum Member Username: LklivesPost Number: 11139 Registered: Jan-06 | It SUCKS BIG TIME!...Buy either a Sonicview 4000 ($159) or a Viewsat Ultra, comes with free shipping too...and buy from www.globalwholesalers.biz ...they are inexpensive and very reputable.. |
Silver Member Username: Ustaad_hcPost Number: 226 Registered: Oct-06 | 298 bin auto roll you do not have to put keys manually. Just do power scan let receiver updated. wait |
Silver Member Username: Ustaad_hcPost Number: 227 Registered: Oct-06 | Ariza Extreme nobody like that.. |
