Platinum Member Username: LklivesPost Number: 10985 Registered: Jan-06 | Safe for Genuine and Clones of the pansat 2500... Now Turn ON your autorolls and let the keys roll by themselves...may take 1 min to 1 hr... File is from Chancysand Get it here...just remove the * in the link...MUST register FREE... [link removed] or here Safe for Clone 2500's...X-85BL_070812_294T_api.zip....15 Aug |
Platinum Member Username: LklivesPost Number: 10986 Registered: Jan-06 | ftaprosupport link isn't working now...so u can also get the file here...direct link to the file.. |
Platinum Member Username: LklivesPost Number: 10988 Registered: Jan-06 | This direct link to the 294T, 2500 clone safe bin, at |
Platinum Member Username: LklivesPost Number: 10992 Registered: Jan-06 | here's another place that has the 294T pansat 2500 clone safe bin... safe for genuine and clones...remember to turn ON all autorolls... |
Silver Member Username: DoreenakadjPost Number: 478 Registered: Dec-06 | this file works on my fortec lifetime ultra (FLU) cloned to pansat 2500a thanks LK keeep up the great posting |
Platinum Member Username: LklivesPost Number: 10996 Registered: Jan-06 | Here's some CLONES of the Pansat 2500... Fortec Lifetime Ultra (FLU) Quantum 3000 Quantum 3500 Panset 2500 Pantec Lavasat 3200 Megasat yt 6688 Vortex 7700 Eaglestar 2500 Pansat 3000 ACE 2500 |
New member Username: MajikonePost Number: 4 Registered: Jun-06 | Hi Does the 294T for the clone support both Bev and dish on the same receiver??? |
Platinum Member Username: LklivesPost Number: 11014 Registered: Jan-06 | yepper... |
Gold Member Username: NydasPost Number: 3238 Registered: Jun-06 | X-85BL_070812_294T_api.zip (370.8 KB) X-85BL_070812_294T_api-Full Jtag.zip (405.4 KB) Most people use the plain api file, not the full jtag file. |
Silver Member Username: FastbeatzPost Number: 174 Registered: Sep-06 | does anyone know if GC works with this bin on FLU?? i heard it works with 293t but i dont know about 294t....so does it work for anyone? |
Silver Member Username: Destine0429Quebec Canada Post Number: 237 Registered: Dec-06 | Thanks LK, you always do aim to please :D |
New member Username: KazanrovPost Number: 8 Registered: Jan-07 | please I need somebody that help me I set already the 294 for my colne(quantum)but is fantatic you don't need to put the keys mannually but no show hbo eigther ppv also some body can help me please. |
Platinum Member Username: LklivesPost Number: 11037 Registered: Jan-06 | mari...post on another thread...U do not have a BIN issue...and this subject is about bin 294T...Do NOT go around hijacking and stealing threads for your own convenience...U would be banned from any other site for this! |
Gold Member Username: NydasPost Number: 3252 Registered: Jun-06 | miguel mari: The following information will help. When you install 294T BIN you will find that the date is set to 01/01/2006 and the time i set to midnight Pacific time. all the autoroll features will have been turned on. You should go into user settings and change the date, time and time zone. Then switch it off at back and turn it on again. Wait about a minute for keys to roll in and don't be impatient. The picture will come in without any further effort on your part, because the BIN does not do anything to your scans. |
Bronze Member Username: MvpQuebec Post Number: 12 Registered: May-06 | can someone tell me file X-85BL_070812_294T_api-Full Jtag.zip (405.4 KB) is good for fortech |
Platinum Member Username: LklivesPost Number: 11050 Registered: Jan-06 | fast beatz...i'll save u some time...since nalin is just a LIAR and clueless...I didn't answer U directly earlier cause I wanted to see nalin's expected BS answers instead... THE NEW PANSAT 2500 AND CLONE BINS (294 AND 294T) DO NOT HAVE GLOBECAST ENCRYPTION DUE TO THE LIMITED MEMORY IN THOSE RECEIVERS...AND THERE WILL NOT BE GLOBECAST (GC) IN ANY 2500 OR CLONE FOR A VERY LONG TIME, IF EVER! If U want Globecast U will need to upgrade to a newer Pansat and bins which do have the GC encrypted codes..and some other receiver companies may have them too soon.. If U ever do upgrade to another Pansat, here's how ya change the keys manually... Press 8282 while viewing a channel or go parental control....2nd pin....nagra 2.. Once in the nagra2 menu go to the C101 provider ID and enter keys |
Platinum Member Username: LklivesPost Number: 11051 Registered: Jan-06 | mvp...there are many sites with the Jtag for the Fortec Ultra...but yes, the Ultra is a 2500 clone Personnaly I see no point in Jtagging a Fortec...any Fortec...cause they are garbage...unless u have plenty of time and patience... Break down and buy a decent receiver like a sonicview 4000 for about $159 with free shipping... http://www.globalwholesalers.biz/prod46.htm |
Gold Member Username: NydasPost Number: 3267 Registered: Jun-06 | mvp: You can do a Fortec ultra to Pansat 2700 conversion if you want to - it has to be jtagged. As is, it will work fine with Bin 294T. LK is promoting this US dealer so he can get a commission. By the time you consider the strength of Canadian dollar and the shipping costs, etc., you are better off buying from a reputable dealer in Montreal or Quebec. Make sure you get a warranty and get advice about installation issues from your local dealer of Sonicview/Viewsat |
Platinum Member Username: LklivesPost Number: 11056 Registered: Jan-06 | I do NOT receiver funds from ANY FTA dealer or site!....obviously nalin U know nothing about FTA... if he could use the 294T bin, then he wouldn't be asking how to Jtag his receiver...are U that stupid, seriously? and converting to a 2700 is not easy, and the bins are very rare....they require VERY special modded 2500-2700 bins from ONLY jvvh....nalin, U definitely couldn't do a simple Jtag!...nevermind this 2700 conversion |
Silver Member Username: DoreenakadjPost Number: 479 Registered: Dec-06 | I am going to say "why mess with the (flu) 2500a if it works?". Up ontill this new bin ( 294T ) came out, i was using 292T (with key changes) but it did/does work still. I just got this new bin for the auto roll. Its not worth converting a (FLU) they are soon to be worthless door stops anyway. Buy a newer receiver from whome ever you want to and have fun with it. But please read any info on a newer receiver that you can get your hands on and learn all about it with INFO FILES, VIDEO FILES ....etc |
Gold Member Username: NydasPost Number: 3270 Registered: Jun-06 | One point people are not aware of about the FLU and Pansat 2500 clones. These usually have more memory than the Pansat 2500. Therefore, the proposed or predicted obsolescence of the whole Pansat 2500 and clone family is strictly not correct. The 294T is working fine on clones. |
Gold Member Username: NydasPost Number: 3284 Registered: Jun-06 | The Pansat 2500 and clone BINs were out 2 days ago. Today there is alot of new BINs out for the rest of Pansat family. The site has a new entrance and the latest files are dated yesterday and today. You can easily download - traffic is light or the servers are much better. BINs are dated yesterday or today -9000HD: Download available - 250SM: Download available - 3500SD: Download available - 2800A: Download available - 2700A: Download available - 6000HXC: Download available - 5000: Download available |
Silver Member Username: LetmeonPost Number: 147 Registered: Mar-06 | Pantec 294t bin autoroll working for anybody ? had morphing keys yesterday. |
Gold Member Username: NydasPost Number: 3307 Registered: Jun-06 | Revert to manual input of keys and autoroll off. |
Bronze Member Username: PsychmonsterChi town, Il USA Post Number: 70 Registered: Jul-06 | Lk is right about the 2500 conversion...you need a dump file that has been specifically written for the 1 mg chip of the 2500 and only one or two peps have written it or added to it and once burned, you must jtag every new bin update, still highly experimental but have heard it works & executes even faster than BL's bins..one way or another, either you may have to upgrade to a 2mg chip and then erase and burn the factory 2700 bin and then write the BL 2700 bins or do this experimental 1 mg dump bin file to continue with the 2500 for the near future..check out this great site for some incredible insights and downloads on how to do this conversion, but at your own risk !! |
Silver Member Username: HanzPost Number: 340 Registered: Oct-06 | I just loaded the 294T bin on my old Pansat 2500 clone using the Blacklist Updater v 1.4. Now I'm getting night rider lights. Did I use the wrong loader? |
Platinum Member Username: LklivesPost Number: 11138 Registered: Jan-06 | Thats the correct loader, BL v 1.4...upload an older bin...be persistent...U can even upload the factory Pansat 222 or 224 bins... get the loader ready and select the bin...shut off receiver with rear switch...then c click on "write bin" and immediately turn ON receiver with rear switch...its all about "timimg"... BTW...make sure U have the straight cable and good and tight connections.. |
Silver Member Username: HanzPost Number: 341 Registered: Oct-06 | Thanks LK, I'll try this. |
Bronze Member Username: Pu_da_mundaPost Number: 20 Registered: Feb-07 | DN keys plz..... |
Bronze Member Username: Kimo74Post Number: 46 Registered: Jan-07 | hi there I have a fortec ultra receiver. I downloaded the 294T Bin, and turned the autoroll on, but it doesn't autoroll. is there any thing special i was suppose to do, i simply downloaded the file to the receiver, and turned on the autoroll after i put the latest keys. Please let me know. |
Gold Member Username: NydasPost Number: 3368 Registered: Jun-06 | kamal: The day after the 294T was released there is new small ECM. Most of the other receivers have a new BIN. You should turn autoroll off and enter keys manually. You will probably need to change the first number in key 00 and key 01. Also see this thread, for a quick change of keys when they change. https://www.ecoustics.com/electronics/forum/home-video/380341.html |
