New member Username: Bugsbunny_satellitePost Number: 8 Registered: Jun-07 | Sorry to bother everyone..I have a Pansat 3500sd and I have been triing to download the new numbers to my receiver. When i click on the Loader and then click in bin file and then press open I get a message saying (unknown file type)I press ok to that message but then I press download I get another message saying ****(Bin file does not correct download was prohibited)**** is there any other way or how do I open this file to do my download...Please help I really do appreciate it. Thanks to all |
Silver Member Username: MrrasecPost Number: 227 Registered: Jul-06 | are you sure that the bin is unziped? |
New member Username: Bugsbunny_satellitePost Number: 9 Registered: Jun-07 | thanks for replying...how do I unzip this.I am not knowledgeable on this at all..please help |
Platinum Member Username: LklivesPost Number: 11093 Registered: Jan-06 | www.winzip.com |
New member Username: Bugsbunny_satellitePost Number: 10 Registered: Jun-07 | Thanks..I have windows 98 and i just went to the site and the system requirements are windows 2000 |
Bronze Member Username: Bugsbunny_satellitePost Number: 11 Registered: Jun-07 | thanks..I have windows 98 and winzip require windows 2000 |
New member Username: SpeedbumbFort mc murray, Alberta Canada Post Number: 1 Registered: Aug-07 | just getting started dont know how to download the keys on to a pansat 3500sd could someone please help me . |
Platinum Member Username: LklivesPost Number: 11135 Registered: Jan-06 | winzip will work easily on OS windows 98...believe me , I know! |
Bronze Member Username: CaliPost Number: 73 Registered: May-06 | Where are the pansat 3500s bins? |
Silver Member Username: Thechiz2Mars, Ur anis Mine Post Number: 235 Registered: Apr-05 | (Bl version 325) GlobeCast & Dish A/R Fix 3500SD Off Site DownLoad |
Gold Member Username: NydasPost Number: 3360 Registered: Jun-06 | You can get to all the Pansat download via megaupload by going to |
