Pansat 3500sd jtag help!!!!!!!
Username: Dazedone
Des Moines, Iowa USA
ok. tried jtaging using skybox and wall+jkeys. on one reciever it took jatag and boots up fine upgraded to b80 loaded latest api file. every thing works but all channels come up scrambled or bad channels even Nasa which is true fta did I miss something? ok on to the other reciever it will not take jtag. like the other I tried using both utilities and keeps comming up with write fail errors is there a work around. if it matters I got the one reciever that will not take b80 ready from dealer. man tired of banging my head up against the wall. can someone please help!!!!!!
Username: Rtap
FL
Post Number: 302
enter the latest keys and turn off autoroll. then scan the birds.
Username: Dazedone
did it and nothing. no channels found during blind scan. any other suggestions
Username: Runnerguy
Pluto
Post Number: 526
John!! Google : "jtag pansat 3500" and you will see 2 links to dsstester that are hard to boot up right now because of current overload. You should get all the info you need. You may need a little soldering skills and a jtag cable which are on sale now at Ebay for less than $3.00. Please keep this forum informed with your findings even if you give-up.
