New member Username: Trans_am_ls7Post Number: 1 Registered: Aug-07 | lookn for a 15" or a 18"??? i want to get deep and loud!! |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1618 Registered: Nov-05 | what amp will be used? BTL is leagues above other 2 |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1619 Registered: Nov-05 | in power handling^^^^^^ sorry |
New member Username: Trans_am_ls7Post Number: 2 Registered: Aug-07 | i'm thinking of sundown saz-3000d for the btl |
New member Username: Trans_am_ls7Post Number: 3 Registered: Aug-07 | The fully loaded BTL. the full cooling, the high Xmax coil and the 3rd magnet 3,500 rms |
Gold Member Username: 420alldaylongPost Number: 2481 Registered: Sep-06 | The Q is there sq sub and it will shine on 1200-1300RMS. |
New member Username: Trans_am_ls7Post Number: 4 Registered: Aug-07 | wich one wold u go with the Q or BTL?? |
Gold Member Username: 420alldaylongPost Number: 2483 Registered: Sep-06 | I world get a SI Mag 15" and a SAZ-1500D. |
New member Username: Trans_am_ls7Post Number: 6 Registered: Aug-07 | i'm sorry i never heard of SI Mag |
Gold Member Username: 420alldaylongPost Number: 2484 Registered: Sep-06 | http://www.stereointegrity.com/ |
New member Username: Trans_am_ls7Post Number: 7 Registered: Aug-07 | sorry man it looks good! but i'm tryin to get a fi sub |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 422 Registered: Apr-07 | SI Mag > Fi, but if you really want Fi go Fi Q with a Kicker zx1000.1 you'll be happy. |
Gold Member Username: 420alldaylongPost Number: 2485 Registered: Sep-06 | Of course SI Mag over Fi |
Gold Member Username: 420alldaylongPost Number: 2486 Registered: Sep-06 | Trans Am LS7 What is your budget for amp and sub? |
New member Username: Trans_am_ls7Post Number: 9 Registered: Aug-07 | 1,000 i got a usamp 2000d and two re se on it? |
Gold Member Username: 420alldaylongPost Number: 2488 Registered: Sep-06 | What's the model number of that amp? |
Bronze Member Username: Trans_am_ls7Post Number: 11 Registered: Aug-07 | IDK it's under the box it's new |
Gold Member Username: 420alldaylongPost Number: 2489 Registered: Sep-06 | Is it the XT-2000D is so this is there entry level amp but still ok but I'm not sure if it pushes rated power. XT-2000D 4ohm 150x1 2ohm 300x1 1ohm 1200x1 So you want new amp/sub? For around/under $1000 |
Bronze Member Username: Trans_am_ls7Post Number: 12 Registered: Aug-07 | i got the box it say XT2000D XTERMINATOR Series 4ohm 150x1 2ohm 300x1 1ohm 1000x1 on the website it say 1ohm 1200x1 what up with that???? |
Gold Member Username: Skibum12189Cleveland Post Number: 1444 Registered: Mar-06 | 2 Fi Q's 2 Sundown SAE 1000's do you really have a trans am with an ls7? |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 9329 Registered: Jun-06 | "i'm sorry i never heard of SI Mag" It's ok. We forgive you. |
Bronze Member Username: Trans_am_ls7Post Number: 13 Registered: Aug-07 | yea i put alot in this car!! now i got a 06 ford Explorer! i have 2 12" se right now. now i want to try 1 or 2 18" |
Bronze Member Username: Trans_am_ls7Post Number: 14 Registered: Aug-07 | is there any diff b/t the Q and BL ???? |
