New member Username: Tdjewell20Smithsburg, Md U.S Post Number: 2 Registered: Aug-07 | I got these wires on accident..will they be fine to hook up a 300 watt amp? |
Silver Member Username: SomedonniedudePost Number: 108 Registered: May-07 | Thats really pushing it, what vehicle are you putting it in or how many feet away is the amp from the battery? How many feet of wiring do you have? |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 9265 Registered: Jun-06 | Hit me up if you need some 2ga wire. I have many amp wiring kits available. Just throwing it out there. $50 shipped.![]() |
Platinum Member Username: James1115Use a simple... Post Number: 10162 Registered: Dec-04 | I would not recommend anything smaller then 8 ga. I would hit Paul up and buy a kit from him. That way you will only have to wire your car up once when you upgrade later. Paul is one of the few people on this site who I will vouch for 100% as a seller. For $50 I would go that route. |
New member Username: Tdjewell20Smithsburg, Md U.S Post Number: 4 Registered: Aug-07 | its a 89 hyundai sonata....but the wire is 17 feet and its in the trunk...i'm trying to go a cheaper route the the wiring kits just trying to make the sound a little better..but thanks! |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1372 Registered: Mar-04 | what amp? |
Silver Member Username: SomedonniedudePost Number: 113 Registered: May-07 | Hey Paul do you work at a shop or own one? I was just wondering if you do and if you had a website that i could look at to see what all you got. $50 for 2 ga kit is pretty resonable. |
New member Username: Tdjewell20Smithsburg, Md U.S Post Number: 5 Registered: Aug-07 | its a 300 watt visonik amp. Ok i know nothing but can you explain the gauges please |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1377 Registered: Mar-04 | www.bcae1.com/wire.htm |
New member Username: Tdjewell20Smithsburg, Md U.S Post Number: 7 Registered: Aug-07 | Thanks alot! |
