Help please
Username: Rated08
Post Number: 23
half of my channels are breaking up pretty bad. espn,discovery channel, spike tv and others. Other channels work great, just like normal. Is it the cable connection going to the back of the box or is it the dish.
Username: Rtap
FL
Post Number: 309
need more info
what box,bin file,setup
Username: Rated08
Post Number: 24
view sat 2000, the lastest bin file not sure which one.
Username: Donnie1973
Post Number: 675
it is most likely your dish angle. Check your signal strength.
Username: Lklives
Post Number: 11219
U can change your own cables without asking here...we have NO crystal ball here...it could be
weather
bad cable or connections
trees or something in your "clear line of sight" from the dish
U need a new scan
poor dish alignment
bad switch, if using one
incorrect receiver antenna settings
U must do a process of elimination yourself...
