Just got back from slap show
Username: Talon01
York, Pa Usa
Post Number: 35
took 3rd i hate ac mics lost by .2 for 2nd and.3 for 1st
Username: Loudon
Post Number: 1514
what ac mic was it the 190? if so thats very similiar to a tl .. sometimes harder to do a certain number then tl ...
Username: Talon01
York, Pa Usa
Post Number: 36
no its a 180
Username: Loudon
Post Number: 1515
ahhh ic ic ...
what equip u using man?> i gather u have an eagle talon
Username: Talon01
York, Pa Usa
Post Number: 37
no a jeep liberty i am seans bro with the 12 2.5 audioque and the mtx4501 500watts
Username: Loudon
Post Number: 1517
ohh i gotcha ... nice sub ... way above the entry level title people give it
Username: Talon01
York, Pa Usa
Post Number: 38
most definitley the 2nd place guy was a 12 cv stroker and 1st was 2 10 diamond audio, so that says alot for the que and a little bit of good designing
Username: 420alldaylong
Post Number: 2479
I'm not doggin AQ(i love em)but the Cerwin Vega stroker should of took it easy. Unless he is a dumbazz and knows nothing about install. A friend of mine has two AQ SD2.5 15" on a Crossfire VR1000D. I like it alot for a 1200-1300 watt setup. Oh yeah what was your number
Username: Talon01
York, Pa Usa
Post Number: 40
the ac said 141.8 but that meter was tight as crap
Post Number: 2490
How much power was the other two using?(12" stroker,two 10s diamond and what diaamonds were they)
Username: Talon01
York, Pa Usa
Post Number: 42
the diamond audio 10's was running 1000 watts rms alpine amp
and the cerwin vega stroker was running a audiobahn 1800 1dt amp I think. So basically double my power by either competitors
