Alternater
Username: Ghavens1981
Lexington , Ky United states
Post Number: 15
who do i need to talk to or where do i need to go for a bigger alternater
Username: Th3pwn3r
Post Number:...
Post Number: 5048
Iraggi alts can be found on Ebay or Excessive amperage.There's also Ohio Generators but I hear a lot of bad things about them.There's lots of options depending on what kind of car you have.
Username: Nd4spd18
Northwest PA
Post Number: 3225
Ohio Gen are very good but expensive. Iraggi alts are good,
So are DB electrical. They often have the best price too, but they're only for american vehicles.
Username: Th3pwn3r
Post Number:...
Post Number: 5068
I've heard tons of bad stories about Ohio Gen though...I've never run one personally but I a couple guys from CA.com said they put Ohio Gen alts up against Iraggi alts rated for the same amperage and the Iraggi alts absolutely destroyed the Ohin gen alts.
