Keys for pansat2500
Username: Pitbull_1
Post Number: 7
need keys please, my receiver accepts 16 characters per set,32 in all,cant find them in threads.
thanks
Username: Dude123
Post Number: 1074
turn off your auto roll and enter these keys manually
Dish Network (0101)
(Last Update: Thu. Aug 16, 2007 4:00 PM EST)
86: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 Active
96: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
Bell ExpressVu (0901)
(Last Update: Thu. Aug 16, 2007 7:08 PM EST)
86: 5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD Active
96: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40
Username: Flatulant_kitty
Post Number: 248
Which thread would you like to work with?This one or the other?Or do you want someone else's advice.
Post Number: 249
Now you really got him messed up with that 86: 96: stuff.
Username: Pitbull_1
Post Number: 9
I am open to anyones advice on this topic,but if you can help I will return to original thread,
thanks
Username: Pitbull_1
Post Number: 10
yes those keys do not fit
Post Number: 250
Press menu and move to system info.
A box will pop up showing what software is installed.
Report back.
Username: Pitbull_1
Post Number: 11
what receiver do those belong to??
Post Number: 251
Same #s for all receivers.They just get put in a little differently.
Post Number: 252
Notice the key# 00.
If you highlight it and press volume up one time it will change to 01.
Two groups.00 and 01.Each 32 digits.
Username: Pitbull_1
Post Number: 12
ok hold on
Post Number: 253
The #s 86: and 96: are the same as 00: and 01:
Username: Themangod
Post Number: 148
heres a key code grabber ripper that has new key codes.
[link removed]
some of the other key code masters dont have the working keys displaying and some have errors this one is really simple works well and has new working keys.
Username: Pitbull_1
Post Number: 14
x-85bl
boot ver 5.1
Post Number: 254
Thats only part of it.Need the bin # too.
Did you get the 00 and 01 thing i just mentioned?
Username: Pitbull_1
Post Number: 15
thanks kate
Username: Pitbull_1
Post Number: 16
yes,but i dont see a bin #
Username: Pitbull_1
Post Number: 17
perhaps -ap1:2.93at_eu?
Post Number: 256
Has this thing worked before this.
Should say like...
X85BL
API 293a eu
Boot ver 5.1
11 apr.2007
Future FTA INFO.
Username: Hi09
hey - got a Viewsat extreme update the BIN few days ago - any ways today i turned off the auto roll, then entered the following keys:
00: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03
01: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
but same thing just says no audio no video, its my first time entereing keys manually any special steps?
Post Number: 257
OK bin is good.
Press menu-Parental Control-second pin-0000-nagravision 2.
Move down to key #00 and press volume up and 00 will change to 01.
You should see 32 digits for each 00 and 01.
Username: Pitbull_1
Post Number: 18
does that help kitty?
Username: Pitbull_1
Post Number: 19
yes all correct except for mine is
ap1:2.93at_eu
Username: Pitbull_1
Post Number: 20
yes it has that,sorry computer is slow
Username: Pitbull_1
Post Number: 21
yes it worked up to the last long weekend and it hasn't since
Post Number: 258
Did you find the KEY 00 and 01 thing?
Username: Pitbull_1
Post Number: 23
yes
Post Number: 259
Make sure to press OK before you exit from nag 2 screen.OK will blink on screen.Also move auto roll options press ok. Leave key code on and turn off all 3 auto rolls.
Username: Pitbull_1
Post Number: 24
tried that still no picture let me try to enter keys again, hold on
Post Number: 260
One wrong and no workie.Double check and don't forget to press ok when done.Make sure A/Rs are turned off.
Username: Pitbull_1
Post Number: 25
same problem cant find new keys that fit my key holders
Username: Pitbull_1
Post Number: 27
keyfinder kate gave me gives keys with 2 many characters
Post Number: 261
You cant find where to put the keys is your problem.The keys fit everyones but yours?
If you cant find room for the ones posted you won't find any that will.
Post Number: 262
The keys are posted 3 times or more in this thread alone.
Post Number: 263
The 00 and 01 and the 86 and 96 are not part of the keys.
Post Number: 264
One last try.Looks like this.
key 00:
key 01:
Username: Pitbull_1
Post Number: 29
yes that is correct
Username: Pitbull_1
Post Number: 30
let me try again
Post Number: 265
Huh?What?Whats correct?
Username: Pitbull_1
Post Number: 31
nope no dice,this box has a couple different key boxes on it,i put the keys in the ones that fit but still no picture
Username: Doreenakadj
Post Number: 492
turn everything (off) but the key code leave that (ON) then the keys that Kitty gave here will work
Username: Pitbull_1
Post Number: 32
what about the other key boxes,dont they need keys too?
Post Number: 266
You need the 32 digits posted, put into the correct place.Or your not going to get anything.If you don't turn off the A/Rs too then you get nothing.
Gotta ask what provider are you trying to get?
Username: Pitbull_1
Post Number: 33
my receiver has 5 sets of key boxes
Username: Pitbull_1
Post Number: 34
o1o1
Post Number: 267
0101 is DN.
Bellow that is 00.See that?
Username: Pitbull_1
Post Number: 35
yes
Username: Kukkudo
Post Number: 39
hey bruce what u need to do for 0101 is input the D**h keyz and hit right on the remote and 0901 will come and thats for b*v for example 0101 u will go down and start inputing keyz than hit ok and save then go to 01 put the rest of the keyz in hit ok.
Post Number: 268
Bellow that is key data.
Should be 16 digits there?
Post Number: 269
Sorry 32 digits.2 rows of 16.Right
Username: Pitbull_1
Post Number: 36
yes did all of the above,still no picture
sat. signal and quallity signal are all 88%
Username: Spesci
Guys I can't get it to work either.
For Bev what row number do I use?
Username: Pitbull_1
Post Number: 37
thanks for your help guys im given up for a while
later
Username: Kardary7
Nashville, T.N
Post Number: 9
hi guys that is new keys but you have turn off autoroll option
keycood on
dishnet autoroll off
bev autoroll off
Dish Provider 0101: Last Updated (16 Aug '07 4:00 PM EST)
Key 0: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 (Active)
Key 1: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
Bev Provider 0901: Last Updated (16 Aug '07 7:16 PM EST)
Key 0: 5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD (Active)
key 1: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40
Thu, 16 Aug 2007 19:13:46 CDT
Username: Spesci
What Ident do I use for B*V, using a c00ls@t 7k
Username: Rah
New York, NY USA
Man Down Can anyone help I have been down for two weeks now and I have tried putting new keys in but they don't work can some one help.
Username: Rah
New York, NY USA
All is Good These Keys are Active.
key 00:
key 01:
Username: Rah
New York, NY USA
hay guys the keys that I just posted ran out after 30min can any one explain? I need to know what I should do with my receiver now. someone please help.
Username: Abdou91
514
Post Number: 92
you need to upgrade soon
and keys chage now
key 01 is for dN
D047365D5BF22766
56D096C83F85AFD9
