Big 3
Username: Aj1218
Post Number: 49
Hey everyone...do any of you know how to wire the big 3 or if there is a link on how to do it?
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1524
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
Username: Aj1218
Post Number: 50
Great info...my only question is what wire to put the fuse on. I plan on using 1/0 wire so what amp rating should the fuse be also?
Post Number: 1536
I believe you are referring to the wire that runs from the battery to the alternator. You are supposed to fuse it for what your alternator is rated at.
ex. I have a 200A alternator so my fuse is a 200A fuse.
Now some people do fuse and say that you dont need to. But I just did it to be on the safe side.
Username: Kklagge
San Diego
Post Number: 486
I thought you were supposed to fuse it at what the wire is rated for and not the alternator size?
I have a 300amp fuse on mine...as well as a 300amp fuse on my 0/1 gauge amp wire before it get to the distro block which has 150 & 60 amp fuses
Username: Th3pwn3r
Post Number:...
Post Number: 4256
I don't have any fuses.
Post Number: 1569
"Now some people do fuse and say that you dont need to. But I just did it to be on the safe side."
LOL. I dont know what I was saying, but what I meant was...
Some say you dont need to, some say you do. But I chose to do it anyway.
