My SSF
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 886
How do i set this on the kicker zx750.1
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 3971
sub sonic filter should be set to the tuning of your box.. a little bit under
so if your box is tuned to 35 hz set the ssf to 30hz
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1578
With the 750.1 and I think all kickers, the subsonic filter is just a switch (On/Off). So you cant fine tune it, I believe it is set in the 20Hz range
Post Number: 887
alright thanks
