Silver Member Username: TornPost Number: 132 Registered: Jan-07 | Which is built better and more powerful zapco or kicker amps? |
Silver Member Username: KravenbloodOhio Hmmm Post Number: 281 Registered: Aug-05 | i would love to have the zapco c2k9.0x the 4 ohm version.. depending on what models your looking at id go zapco |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1917 Registered: Jul-05 | zapco is built much better but it depends on what models your looking at... and kevin is right the c2k9.0x is a beast. |
Silver Member Username: FearthisskyyDallas, Texas United states Post Number: 381 Registered: Apr-07 | http://ampguts.realmofexcursion.com/ see for yourself i would vote on zapco if it's the upper end models. more powerful? depends on which one you get, they will both do rated power, and kicker tends to underrate by quite a bit. |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1919 Registered: Jul-05 | one of my favorite amps to look at... http://ampguts.realmofexcursion.com/Treo_SSXD1500.1/ |
Silver Member Username: TejcurrentPost Number: 201 Registered: Apr-07 | zapco is known for great quality, but power wise it will depend on what model you're looking at. |
Silver Member Username: TornPost Number: 133 Registered: Jan-07 | treo and zapco are friends or something? i see a link to zapco in under the links with header of Here you will find links to the coolest car audio websites. GG |
Silver Member Username: TornPost Number: 134 Registered: Jan-07 | wtf? Bump! more opinions needed ![]() |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12674 Registered: Jul-05 | a watt is a watt....get what ever you can afford and fits ur system |
