New member Username: ArabiankillerHamilton, On Canada Post Number: 2 Registered: Aug-07 | i have a problem. sometimes the key i put in gets changed. The firs letter or number. How can i stop that from happenening? | |
Silver Member Username: CanndyPost Number: 429 Registered: Nov-06 | NEW KEYS NEW KEYS [link removed] GLOBECAST KEYS NEW |
Gold Member Username: NydasPost Number: 3182 Registered: Jun-06 | cotton coots: Keys are security measure used by providers. Usually there are two lines of 16 two digit hex numbers. They are referred to as Key 00 and Key 01. Both the lines have to be entered in full and have to be present for the receiver to work, so in reality, there is nothing like Active and passive keys. The last changed key is usually denoted Active key. Autoroll in a software BIN started about 9-10 months ago. In this the new software allows the new keys to 'roll in', so there is no need for manual entry. There have been many changes in the way the autoroll work and every time such a change occurs the old autoroll software stops working well. The last such change was about 12 days ago and in most receiver we have a 'fix' i.e. a change in the BIN, such that the autoroll works well. Not so with the Pansat 2500A, a receiver widely used. We still need to install the keys manually. There is some relief however. With the 293 and 293T BIN, the keys do roll in whether you have the autoroll set to off or on. However, the first digit in both key 00 and key 01 gets changed '" the top bit get inverted and you have the first digit shifted by 8. If therefore, you allow to let the keys roll in, and change the first digit of first number (both key 00 and key01) by adding or subtracting 8, you will get the correct key, which you can save and watch TV. Why has Pansat or BL not implemented this change so far? '" I really do not know. Why are the keys changing so often? '" it is DN and BEV's decision to keep on putting their own security measure as often as they wish. |
New member Username: Ariza_700Post Number: 3 Registered: Aug-07 | Hello folks I need some help: I have ariza 700 and I am using 295eEU bin file. I am using the following active key : 00: B8 7C AA A2 23 57 2D 44 FF 91 9C E6 39 53 50 9C For some reason the first digit of the key(B8) is keep changing into 38. I have tried different setting : 1) AUTOROLL/EMU: ON or OFF but the screen is keep updating the data. The data update goes to 500 % and start again. when the data updated the first digit of key will change again. Any help will be greatly appreciated. Thx |
Gold Member Username: NydasPost Number: 3183 Registered: Jun-06 | ariza 700: Read my long post just above yours. Ignore the long wait. Keep autoroll off. when your picture goes, turn autoroll off, switch off and on at the back, and wait for about 1 minute. The keys will have rolled in but the first digit is changed in both key 00 and key 01. Change it by subtracting or adding 8. Turn autoroll off and watch TV. |
New member Username: AlazadamPost Number: 1 Registered: Aug-07 | I have a Faortecstar lifetome Ultra reciever andi want to upgrade it to 294T bin I heard it's out already.Please help me to find a website from where i can download the 294T bin Thank you |
Bronze Member Username: K98Post Number: 73 Registered: Jan-07 | thank you nalin good info glad you are back keep up the good work you are the best sincerely cotton coots k98 | |
Gold Member Username: NydasPost Number: 3184 Registered: Jun-06 | Abdel Aziz Rajabi : DO NOT USE the 294T BIN till somebody responsible here gives an Okay. besides me, trust, Julie, LK, satscanner, The One, to Okay it. As far as I know there is NO new BIN 294T out yet. |
New member Username: BlueashPost Number: 3 Registered: Jul-07 | Hi i am using viewsat extreme i hav added all latest keys but i cant see indian channels i can only see american channels wht changes shud i do??? | |
New member Username: Sunny12Montreal, Quebec Canada Post Number: 1 Registered: Aug-07 | hi folks, i change my key, signals r coming but picture is not coming, i did blind scan also, but same problem, plz help | |
New member Username: Julian_thomasAtlanta, Ga Usa Post Number: 1 Registered: Feb-07 | Hey guys just got in and put new keys (58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75)and got nothing,am I missing something today. are there new keys? | |
New member Username: LaviniatrifoiToronto, Ontario Canada Post Number: 5 Registered: Aug-07 | thanks forthe keys they work | |
Bronze Member Username: NadxiaDayton, OH USA Post Number: 12 Registered: Oct-06 | Hey Nalin, Nice to have u back. Could you please tell me from where I can download 293 or 293T BIN for my Pansat 2700A. Thanx always |
Bronze Member Username: NadxiaDayton, OH USA Post Number: 13 Registered: Oct-06 | Or Can I have the latest bin for Pansat 2700A |
Bronze Member Username: SrpskkisiinPost Number: 37 Registered: Mar-07 | Dish Keys August 11th 2007 430pm 00:58 EB 99 9E B1 A8 2A EA10 AB 67 BD 2D AA 56 75 01:85 1D AC 71 96 8E 7C 01AB D3 42 A3 C4 D9 CA 62 -- visit |
New member Username: Superstar69Post Number: 3 Registered: Aug-07 | thanks luke smith for them keys keeep it rollin |
New member Username: TammyPost Number: 7 Registered: Sep-05 | Im hoping someone can help me, im trying to get echo 7 and i have found 6,8 does anyone know how far right left up down from 6,8 i need to go? Thanks in advance. | |
Bronze Member Username: GusificationPost Number: 52 Registered: Nov-06 | anyone got keys? | |
New member Username: IntraPost Number: 4 Registered: Aug-07 | D/N Active key 01 : 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 |
Silver Member Username: Pannu16Post Number: 418 Registered: May-06 | dishnetwork 86: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 96: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 |
New member Username: SynisterPost Number: 1 Registered: Aug-07 | Thank you! | |
New member Username: IntraPost Number: 5 Registered: Aug-07 | bad keys pannu ... | |
Bronze Member Username: Top2000doggPost Number: 30 Registered: Jul-07 | yeah pannu bad keys!!! | |
New member Username: Moej1991Post Number: 7 Registered: Jun-07 | keys | |
Bronze Member Username: CacaladPost Number: 24 Registered: Apr-07 | new keys for dish please | |
New member Username: Snw7619Bahamas Post Number: 1 Registered: Oct-06 | why keys keep changing but only second number changing please explain. |
Bronze Member Username: CacaladPost Number: 25 Registered: Apr-07 | keys please for dish | |
Bronze Member Username: Poonam008Post Number: 14 Registered: Nov-06 | 86: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 96:85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 It's working |
New member Username: Guicho01Post Number: 1 Registered: Aug-07 | D/N Active key 01 : 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 |
New member Username: Snw7619Bahamas Post Number: 2 Registered: Oct-06 | i put me keys in manually 2500 pansat dishnetwork which other way can i program sat. |
Silver Member Username: CreekSmithtown, New York Post Number: 370 Registered: May-06 | I'm tired of entering keys! Is there a new file to fix this auto roll? The last one I downloaded was DBPSW-070801X. |
Bronze Member Username: Top2000doggPost Number: 31 Registered: Jul-07 | none of these key work! | |
New member Username: Freddy14Post Number: 1 Registered: Feb-05 | it does not work for me.. pansat 2500 |
Bronze Member Username: Top2000doggPost Number: 32 Registered: Jul-07 | pansat 2500 clone! does anyone know the new keys | |
Bronze Member Username: KhopdiPost Number: 44 Registered: Apr-07 | You f*ing retards. Some of you are toatally screwed. Please f*ing read before you start asking for f*ing keys. A little reading goes along way. Also, pay attention to title thread before you start posting your questions. Again, little research goes a long way. LK, you know what I am talking about. Nalin, I am sick of these neewbies asking dumb questions before doing any research on the topic. | |
New member Username: StormintvSudsbury, ON Post Number: 6 Registered: Jul-06 | Hey Momar Kadopi, go change your diaper before you come on here. Not everybody catches on as fast as you want them to. | |
Bronze Member Username: NesteaPost Number: 72 Registered: Jul-06 | DN and Bev Keys Feed Nag2 keys ---------------------------------------- Dish Provider 0101: Last Updated (11 Aug '07 6:45 PM EST) Key 0: 58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75 Key 1: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 (Active) Bev Provider 0901: Last Updated (6 Aug '07 12:01 PM EST) Key 0: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 key 1: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 (Active) Sat, 11 Aug 2007 17:46:51 CDT |
Platinum Member Username: LklivesPost Number: 10862 Registered: Jan-06 | DISH - Last Update: 08/11/07 05:28 pm EST 00: 58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75 01: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 Active BEV - Last Update: 08/06/07 12:09 pm EST 00: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 Active 01: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 Khodpdi...I undertsand 100%...People are too lazy to read...or follow simple common sens and post in the correct threads...this thread is a perfect example ...even posting keys here is ridiculous hwn there are so many other key finder utilities and direct links to the latest keys.....and use of autorolls and sites in the "recommended sites" thread would stop 99% of these posts, asking VERY ridiculous already answered 100x questions...... |
Silver Member Username: Mkvl1490Post Number: 106 Registered: Feb-06 | LOL i kind of have a weird problem my bin autorolls when it autorolls, all the keys are correct beside the first letter or number of each one for example 58 - C8 85 - 35 just only the first one. its weird thats the only problem. i know i need a bin, but why its like that |
Bronze Member Username: K98Post Number: 75 Registered: Jan-07 | nalin are ypu tired of posting d.n. keys ifnot please keep us posted if you are tired of us ignorant people then i understand but we really need you back on this site | |
Bronze Member Username: Top2000doggPost Number: 34 Registered: Jul-07 | the dish keys aren't working anymore! | |
Bronze Member Username: Demon101Rochester , Ny America Post Number: 20 Registered: Jul-07 | CAN ANYONE TELL ME THE KEYS FOR GLOBECAST KEYS? FOR BOSNIANN TV? | |
Bronze Member Username: K98Post Number: 76 Registered: Jan-07 | sean look at l k s post they work | |
Bronze Member Username: Top2000doggPost Number: 35 Registered: Jul-07 | at what? what is lks? | |
New member Username: HoochPost Number: 1 Registered: Oct-06 | They aren't working for me | |
New member Username: HoochPost Number: 2 Registered: Oct-06 | I have turned off autoroll and put in latest keys for 01 and nothing happens. Anyone else having same problem. Running Co*ls*t. | |
Bronze Member Username: K98Post Number: 77 Registered: Jan-07 | keys are good check lk last set of #sposted | |
Bronze Member Username: Top2000doggPost Number: 36 Registered: Jul-07 | they were good not anymore! i had the keys but then they just stopped working. | |
Bronze Member Username: K98Post Number: 78 Registered: Jan-07 | LK posted dish network keys for d.n. oo o1 check this reply board your post is on | |
Bronze Member Username: Top2000doggPost Number: 37 Registered: Jul-07 | the 00 is the one i had and it doesn't work anymore! | |
Bronze Member Username: K98Post Number: 79 Registered: Jan-07 | re set de fault then re enter keys sean | |
Bronze Member Username: K98Post Number: 80 Registered: Jan-07 | sean let me know if the keys oo are not working mine is fine i have pansat 2700 | |
Bronze Member Username: Top2000doggPost Number: 38 Registered: Jul-07 | i have it doesn't work! i have a megasat yt6688 which is a pansat 2500 clone!! | |
Bronze Member Username: K98Post Number: 81 Registered: Jan-07 | sorry i dont know about your eq. nalin is a good source to contact on this site | |
New member Username: Hydro_blazerPost Number: 3 Registered: Aug-07 | New Keys Please | |
Platinum Member Username: LklivesPost Number: 10863 Registered: Jan-06 | DISH - Last Update: 08/11/07 08:35 pm EST 00: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 Active 01: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 BEV - Last Update: 08/06/07 12:09 pm EST 00: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 Active 01: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 For all receivers!!! |
Bronze Member Username: TausifPost Number: 11 Registered: Jul-07 | New KEY Pl. | |
New member Username: Snw7619Bahamas Post Number: 3 Registered: Oct-06 | thank LK working now keys going off like every 2-3 hours why |
New member Username: Snw7619Bahamas Post Number: 4 Registered: Oct-06 | DISH - Last Update: 08/11/07 08:35 pm EST 00: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 Active 01: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 |
Bronze Member Username: CacaladPost Number: 26 Registered: Apr-07 | new keys please | |
New member Username: Snw7619Bahamas Post Number: 5 Registered: Oct-06 | autoroll off | |
New member Username: Superstar69Post Number: 4 Registered: Aug-07 | thanks for the keys LK | |
New member Username: Snw7619Bahamas Post Number: 7 Registered: Oct-06 | braves winning over phillies mets tied marlins thats dishnet |
Bronze Member Username: K98Post Number: 82 Registered: Jan-07 | thanks lk for posting the oo numbers so fast how do you get them so fast | |
Bronze Member Username: JuanjosePost Number: 36 Registered: Jun-06 | thanks for the keys shannon wong | |
New member Username: Hydro_blazerPost Number: 4 Registered: Aug-07 | Thanks LK | |
Platinum Member Username: LklivesPost Number: 10864 Registered: Jan-06 | U want keys fast...then use these DIRECT links below or download they key finder utilty program to your computer desktop "Keymaster 4.0" here's keymaster 4.0 [link removed] ...remove the * from this link...then register FREE...its a good site too for all new files and manuals and guides... Direct links to keys.... [link removed] [link removed] [link removed] |
Platinum Member Username: LklivesPost Number: 10865 Registered: Jan-06 | U want keys fast...then use these DIRECT links below or download the key finder utilty program to your computer desktop "Keymaster 4.0" here's keymaster 4.0 [link removed] ...remove the * from this link...then register FREE...its a good site too for all new files and manuals and guides... Direct links to keys.... [link removed] [link removed] [link removed] |
Platinum Member Username: LklivesPost Number: 10869 Registered: Jan-06 | Heres the Latest GlobeCast keys.... GC - Last Update: 08/11/07 12:00 am 00: 0F 2B 8A 31 84 D7 2D 2B 40 FF 5E 0B B7 DB 0D 4A Active 01: 83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1 |
New member Username: AdnomPost Number: 2 Registered: Aug-07 | Thanks LK for the keys | |
New member Username: Memin1Post Number: 2 Registered: Aug-07 | hey everybody im new to this stuff can someone plese give me the new keys for the DN please thanks | |
Silver Member Username: Destine0429Quebec Canada Post Number: 226 Registered: Dec-06 | Here ya go Mario. You should look above before you ask. Since the keys are always posted here. Do you know how to manually enter them in? -------------------------------------------------------------------------------- DISH - Last Update: 08/11/07 08:35 pm EST 00: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 Active 01: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 Key number 00, where is says Active after it, means that you only need to enter in this set of keys for the receiver to work. |
Gold Member Username: NydasPost Number: 3185 Registered: Jun-06 | Nadeem: You asked "Could you please tell me from where I can download 293 or 293T BIN for my Pansat 2700A." 293 and 293T BINS are for Pansat 2500A and Pansat 2500 clones repectively. They are NOT for 2700A. For Pansat 2700A you should have upgraded to Boot 75 a few months ago and you should now be using BIN 205 on top of it. The instructions/procedure has to be exact, and you should go to one of the following sites and get the Instructions, the B75 file, the 27.02 loader, factory BIN and the latest 205 BIN. You must follow instructions precisely as posted. All files have to be unzipped before use. If your receiver is a 2700A clone you should use the clone safe 205 Tivo BIN. [link removed] |
Gold Member Username: NydasPost Number: 3186 Registered: Jun-06 | creek: I am surprised that the DBPSW-070801X BIN for Viewsat extreme is not working for you. All reports indicate that it should work, immediately after installation into your receiver. Check the version in your receiver to see if it is the one you have installed |
Gold Member Username: NydasPost Number: 3187 Registered: Jun-06 | sean akins: megasat yt6688 is a pansat 2500 clone. You are probably changing to the latest keys but not changing the first digit of the other set of keys. If you have installed 293T BIN, the keys will autoroll with autoroll on and at time with autoroll off. They will not work till you do a little change. On the first digit od Key 00 and key 01 add or subtract 8. After making the change save it and turn autoroll off. If you are not sure about how to add/subtract 8 to a hex number, somebody has put out a table for you to use in this thread only recently. |
Bronze Member Username: TausifPost Number: 12 Registered: Jul-07 | New KEY Pl. | |
Silver Member Username: KingusamaPost Number: 208 Registered: May-06 | visit |
New member Username: DdljPost Number: 5 Registered: Aug-07 | New Keys Pls. | |
New member Username: Hydro_blazerPost Number: 5 Registered: Aug-07 | New Keys Please | |
New member Username: Keyz_plzPost Number: 2 Registered: Aug-07 | New keys please | |
Bronze Member Username: DannienjuliePost Number: 30 Registered: Jul-07 | I tried putting these keys in but they won't work what's wrong? | |
New member Username: IqqiesPost Number: 4 Registered: Jul-07 | need new keys for DN!! pleasee | |
Bronze Member Username: Bich_dToronto Post Number: 25 Registered: Jun-06 | DN: 86: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 96: 8C F5 E5 42 3D EC 51 4D 52 3E DA 4C 21 DC 86 85 New |
Bronze Member Username: KhopdiPost Number: 47 Registered: Apr-07 | 86:D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 96: 8C F5 E5 42 3D EC 51 4D 52 3E DA 4C 21 DC 86 85 New |
Bronze Member Username: DannienjuliePost Number: 31 Registered: Jul-07 | I tried both sets but they don't work. | |
Bronze Member Username: 1tina_chickPost Number: 83 Registered: Mar-06 | 00: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 01: 8C F5 E5 42 3D EC 514D 52 3E DA 4C 21 DC 86 85 |
New member Username: DdljPost Number: 7 Registered: Aug-07 | Thanks A TON. | |
New member Username: Superstar69Post Number: 5 Registered: Aug-07 | thank you ladies and gentleman them keys works |
Bronze Member Username: MzakcatPost Number: 45 Registered: Aug-05 | they work | |
Bronze Member Username: DannienjuliePost Number: 32 Registered: Jul-07 | Thanks to allI got them working I'm not to smart.LOL | |
Bronze Member Username: 1tina_chickPost Number: 84 Registered: Mar-06 | My Signal is a solid 94 -97 % | |
Bronze Member Username: BabaaliPost Number: 11 Registered: Jul-07 | htank for new keys | |
New member Username: SeetorontoPost Number: 1 Registered: Aug-07 | Hello Guys, Anyone interested in the Latest Viewsat Extreme PGM file email me. my email is seetoronto@gmail.com I am selling it for only $ 6.00 US (six only) Anybody wants it... ??? i can give you the web address where you can buy it... Once you buy it the latest PGM file will be emailed to you within 3 hours. Thank you seetoronto |
Bronze Member Username: Minena77Post Number: 31 Registered: Jun-05 | You can get the latest Viewsat Extreme file for free at It is not necessary to buy it |
New member Username: ZayeshazSurrey, BC Canada Post Number: 6 Registered: Aug-07 | thanx...they workk! | |
New member Username: DsourcePost Number: 10 Registered: Aug-07 | VS BIN
Bronze Member Username: DsourcePost Number: 11 Registered: Aug-07 | Everything your going to need |
Bronze Member Username: DsourcePost Number: 12 Registered: Aug-07 | download keymaster 4.0 for new keys and updated keys | |
Bronze Member Username: DsourcePost Number: 13 Registered: Aug-07 | DISH - August 12 - 96 changed @ 11:00 AM EST 86: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 96: 8C F5 E5 42 3D EC 51 4D 52 3E DA 4C 21 DC 86 85 BEV - August 5 86: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 96: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 GCast - Aug 11 86: 0F 2B 8A 31 84 D7 2D 2B 40 FF 5E 0B B7 DB 0D 4A 96: 83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1 |
Bronze Member Username: CycomykosxtxPost Number: 13 Registered: Aug-07 | new keys? |
