1/0 gauge wire
Username: Evoixmr
Post Number: 51
I need to get some 1/0 gauge wire. Does anyone know if the Tsunami 1/0 gauge kits are any good?
What are the distribution blocks that those kits come with? Do I really need all that sh1t if I already have the 300a fuse that came with the amp?
I also need 1/0 gauge to upgrade the three. Is there kits out there for this that come with all the connectors?
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1543
look at knukonceptz on ebay
Username: Evoixmr
Post Number: 52
I was just lookin at knukonceptz right before I read the post. What would I need to do the big three and install a 2500.1 amp.
Should I get the individual kits or just buy a roll of power,roll of ground, roll of speaker wire, RCA's?
What else do I need?
Distubution blocks?
Batterry terminals?
I want to figure out how to wire my system correctly so I dont Fu(k nothin up.
Ive had a couple homegrown systems before that I threw together so I know the basics, but I've never wired up 2500w. and just want it to be clean.
Username: Evoixmr
Post Number: 53
No one?
Username: Chuck78
Post Number: 122
do you have a HO alt for those 2500w?
Username: Evoixmr
Post Number: 56
No I need to find one, what do I need like 200a?
Also I got a really noob question. I'm wiring 2 dual 2 ohm subs to a mono 2500w amp at two ohms(if that makes sense)
http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~2~I~22
If the amp is sending out 2000w what makes each speaker only get 1000w
Username: Chuck78
Post Number: 124
search for Iraggi alts on ebay and send him an email with the make and model of your car.
"If the amp is sending out 2000w what makes each speaker only get 1000w"
Magical Hobbits
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4852
^^^^LMAO
Username: Th3pwn3r
Post Number:...
Post Number: 4257
The ohm load of the speakers will decide how much power they get.
