Where to buy 0 gage ring terminals
Username: Hgihkcin
Lincoln, NE
Post Number: 223
i cant find any decent quality ones for a decent price, anybody on here selling any?
Username: Chuck78
Post Number: 118
I think I've got a few left over, how many do you need? otherwise check out www.knukonceptz.com 1.75 each
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 607
If you don't want to buy offline they should have some at Lowes or a place like it.
Username: Trey4sports
Post Number: 1614
vtewarehouse.com
idk if they still carry em but you have to buy a minimum of $15 but i got each of my 4/0 ring terminals for 37cents
Username: Safe_cracker
Chicago, IL US
Post Number: 3261
http://stores.ebay.com/Genuinedealz_Closed-End-Tinned-Lugs_W0QQcolZ2QQdirZ1QQfsu bZ5284435QQftidZ2QQtZkm
I buy all my sh!t from this guy, he will combine, good product. I think he even sells a 4/0 ga lug. BTW you don't use crimps do you? If you do you need to get off of them, go get a simple $20 propane torch, go to Radio Shack get a $10 spool of rosin core solder and I will show you how to solder them on! Polo.. :-)
Username: Adddisorder
West palm, Florida
Post Number: 4963
get them from the autopart store they have really good ones at my napa
Username: Hgihkcin
Lincoln, NE
Post Number: 224
ive always used crimps, because i always bought super cheap kits off ebay to do installs on my friends cars. whats wrong with crimps? i already know how to solder are you saying i should get the terminals from ebay like yours then solder the wire in there?
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 838
i can get 1/0 ring terminals for 50 cents a peice from a shop nearby send me some money and ill ship em to u
Username: Nd4spd18
Southeast PA
Post Number: 3186
Crimping is fine if you have the correct tool to crimp heavy gauge wire, thats what I do. Crimp AND solder is the best connection though.
West palm, Florida
Post Number: 4965
yeah crimp and solder
Chicago, IL US
Post Number: 3267
BS, if you can crimp it then the metal is weak! Use a thick sided copper lug witht straight solder, can't beat it! A crimp allows corrosive minerals like road salt and such to penetrate and weeken the copper strands from the inside. You will end up with a hidden problem that will show its ugly face at the end! Polo.. :-)
