Hey man what's happenin? My brother's lookin for some new comps for his honda. I was thinkin some diamond hex's but theyre too pricey i think. We'll be runnin em off a kicker zx450.2 so figure about 150 rms components. Lemme know what you can offer me with MOUNTING depths of less than 2 1/8" bc hes got 1 7/8" plus 1/2 inch spacer" and i think a 2 1/8 would be rubbin....
i know you're the man to talk to buddy and i know oyu can help me out....figure somewhere in the 150-300 dollar range preferably under 250 i think
that will be hard since most CDT components run atleast 2.5in or more. Even the Cl series has a 2.6in depth or close to it. Try looking into JL which I believe will fit under the 2 1/8in depth. Also some of the Rainbows will work for you IIRC.
