I heard there was a new bin out or an autoroll fix or something, is there one for Captive Works CW-600s premium? I'm really getting tired of putting in all these keys. Please help!
were can i get the info on how to download the rollover for the Captive Works CW-600s premium i had a panset 2500a before but this one is different what type of loader do i use and how do i go about it. thanks,greg
Cw 600p v1[1].06 is the loader u want. the 1.43 bin is the latest ar bin.U can load in boot or standby mode but if u load the icon bin ,this has to be loaded in standby mode only. Here is Loader v1.06: [link removed]
U need to input new keys after u shut off the autorolls...
Here is a How Tos guide for all of the features available in CW600s Premium.
=========================== 1.How to change EPG style? (Available in V1.13 Premium) =========================== Now EPG style can be changed to new or old style. New epg style looks great but if you are using full channel name Old epg style will work good for you because it got more room to show full channel names. Here is how you can change EPG style. Main Menu ->System settings-> OSD -> EPG Style -> Old or New
======================================= 2.How to Turn ON/OFF Display Icon feature? (Available in V1.13 Premium) ======================================= Premium model allows you to see Icon in EPG and also on right upper corner of the screen. To make this feature work you have to load the Icon.bin file to your receiver. After you have loaded the Icon.bin file must turn this feature ON/OFF to see Icons in EPG and on screen. Main Menu ->System settings-> OSD -> Display Icon -> Yes / NO
========================== 3.How to set 10/24 channels display? ========================== Main Menu -> System Setting -> OSD -> Scroll down to Channel List change that option to 10 or 24. Now whenever you will press Ok button on your remote it will show 10 channels or 24 channels. If you press F1 key system will sort all of the channels
===================== 4.How to set Event Timer on fly? ===================== With new OSD you can set event timer to certain event that will start in future sometimes on fly. Before set an event timer just make sure EPG is fully loaded. EPG -> Scroll to the event that you want to tune automatically and press "Green" key from your remote. A window will open to confirm date and time that event will start; Now just Press Ok to set.
======================= 5.How to Factory Default a CW600? ======================= New OSD the location for this feature is changed but it works exactly the same as in old OSD. Main Menu -> Installation -> Factory Default
=============== 6.How to set time? =============== Main Menu -> Channels Manager -> Timer -> Time setup
=========================== 7.How to Enable Patch or Disable Patch? =========================== Exit all menus, Press F1 key; the LED will display 'H', then press '000'
=================== 8.How to Edit Patch key? =================== After Enable patch key, go to Main Menu-->Accessories--> Key Menu
======================== 9.How to configure the SID sort? ======================== From main menu->system setting->system->channel No. style can change: Normal: Normal sort order SID sort: Dish order
===================== 10.How to Category Search? ===================== 1) Make sure the epg is loaded- to do that just open the epg screen and see if the boxes are full, if not go choose any box that has no epg and wait 15-20 sec and it will be filled. (You only need to do this once in the beginning).
2) Then exit and hit F2 on your remote.
3) Category box will open, just choose what category you want to watch and hit ok
4) After 2-3 seconds, a list of channels will open which are CURRENTLY playing these categories (every half hour this list changes when a new show is finished or started)
5) Next to the channel there is the title of the show, if you hit INFO button it will open the full information, hit INFO again and it will disappear. Just select what you like and watch.
================ 11.How to Blind scan? ================ BLIND SCAN function can be accessed by going to Main Menu-> Installation -> Antenna Setting -> selecting the satellite that you want blind scan and press Yellow key on your remote.
========================= 12.How to Clone CW600s Box to Box? ========================= From DigitalPlus: 1) Connect the master and slave box with twist RS232 null modem cable (pin2 to pin3, pin3 to pin2, pin5 to pin5). 2) Start the master receiver and press "POWER" key to make it standby "- - : - -". 3) Start the slave receiver, in the master box the led will display 'H' and blink it. 4) Input the password: 111 ---- Transfer S/W 222 ---- Transfer data 333 ---- Transfer data, then S/W 444 ---- Copy whole flash except Boot Loader. 5) After finishing inputting the password. Transfer will begin. When it finish, the LED will Display "-End". Disconnect the cable, start your receiver. Note: By the different password, you can do what ever you want to do for Box to Box.
===================== 13.How to set DishPro LNBs? ==================== DishPro LNB settings can be accessed by going to Main Menu-> Installation-> Antenna Setting-> LNB type-> OCS-DP
=============================== 14.How to Set Legacy SW21/42/44/ Switch? =============================== Legacy Switches settings can be accessed by going to Main Manu-> Installation-> Antenna Settings-> Legacy SW Set the type of switch you got on your dish setup. Don't forget to set DISCQ setting to none otherwise it will not work properly.
=============================== 15.How to set channel lock on certain channels? =============================== Channels can be locked by going to Main Manu->Channels Manager->TV Channels -> Right Arrow-> Lock/unlock go to specific channel and press OK key on your remote.
============================= 16.How to video adjustments option menu? ============================= Video options can be accessed by pressing zero "0" when view your normal TV. Brightness, Contrast, Saturation, Hue, Sharpness and Tint can be adjusted
================== 17.How to Auto TP? ================== Auto Transponder Update can be Turn ON and Turn OFF by going to: Main Menu ->System settings-> system-> Auto TP changed to ON or OFF.
=============================== 18.How to get Twelve hour EPG on a CW600s? =============================== To get 12 hours EPG tune to any channel on listed Transponders. EPG will show 12 hour programming.
Some TPs below help you get 12 hour EPG: Dishnetwork: TP: 12530 For Example CHs : 457 or 517
XXXX: TP:12268 For Example CHs : 212 or 615
===================================== 19.How to change Time setting from Military to Regular? ================================== === To change time from Military to Regular go to Main Menu -> System Setting -> OSD -> Time Display Format change to 12/24.
======================================= 20.How to search Favorite show channel number and time? ======================================= Shows can be searched with start time and channel number by pressing the Click on Find key on your remote -> select OK -> then type your show name and search.
=============================== 21.How to Turn ON/OFF Auto Roll feature? =============================== Autoroll feature can be turn OFF and ON by going to: Main Menu -> System Setting -> OSD -> Autoroll -> ON/OFF
============================== 22.How to Turn ON/OFF key update message? ============================== Key update message can be turn OFF or ON. This feature can be accessed by going to: Main Menu -> System Setting -> System -> Key Update Message -> ON/OFF
======================================= 23.How to turn ON/OFF DN/XXX full name display? ======================================= This unique feature can be accessed by going to: Main Menu -> System Setting -> System -> Scroll down to the next page -> ON/OFF _________________
Topics | Last Day | Last Week | Search | Formatting Tips | Terms & Conditions | Rules | Help | Forum Topics ----------- Home Audio -- Amps -- Cassette -- CD Players -- CD Recorders -- DACs / Transports -- DAT -- DVD-Audio & SACD -- Equalizers -- Integrated Amps -- MiniDisc Decks -- Mini Systems -- MP3 & Audio Servers -- Phono -- Preamps -- Receivers -- Speakers -- Subwoofers -- Tuners Home Video -- DVRs (TiVo) -- DSS/Satellite -- DVD Players -- DVD Recorders -- VCR -- TV Basics -- HDTV Reception -- HDTV Programming -- Direct View TVs -- Plasma/LCD Flat Panels -- Rear Projection TVs -- Projectors -- Screens -- Video Scalers Home Theater -- Setup & Planning -- Speaker Systems -- HTiB -- Surround Sound -- HTPCs -- Bragging Area Car Audio -- Accessories -- Amplifiers -- Disc Changers -- EQs & Crossovers -- Head Units -- Multimedia Systems -- Navigation Systems -- Radar Detectors -- Security Systems -- Speakers -- Subwoofers A/V Accessories -- Acoustic Treatments -- Antennas -- Cables -- Power Conditioners -- Remote Controls -- A/V Furniture Portable Electronics -- Cell Phones -- PDAs/Handhelds -- Headphones -- Portable CD -- Portable DVD -- Portable MP3 -- Portable MD -- Portable Stereos -- Portable TVs Computers -- Desktops -- Notebooks -- Media Center PCs -- Keyboard -- Memory -- Processors -- Mice/Trackballs -- Monitors -- Motherboards -- Networking -- PDAs -- Scanners -- Storage & Media -- PC Speakers -- Sound Cards -- Video Cards -- Cases & Cooling -- PC Accessories Photography -- Camcorders -- Digital Cameras -- 35mm Cameras -- SLR 35mm Cameras -- Medium Format -- Large Format -- APS Cameras -- Webcams -- Disposable Cameras -- Instant Cameras -- Lenses -- Photo Accessories Video Games -- Dreamcast -- Gameboy -- Gameboy Color -- Gameboy Advance -- Game Cube -- Nintendo 64 -- Nintendo DS -- PS1 or PS2 -- PSP -- Xbox Press Releases Submit Articles -- Submit Review Movies Music TV Shows Radio Suggestions? Announcements
Satscanner i got the new loader put in the new bin,com 1, hit start and no download i have the right cable i used it on my panset 2500a i don't know what i'm doing wrong. i did this, 1) Connect your PC and receiver with the Cable (Serial Null Modem) that came with your Receiver.
2) Plug the Receiver into a power outlet.
3) Turn the receiver ON from the switch on the back of the receiver and you will see 00:00 and then press the "POWER" key on front of the receiver panel to make it standby, the LED dot - - : - - will blink.
Note: Loader will not work until you see - - : - - on the LED panel thanks sorry it took so long to get back. greg
It's a crap shoot. LK confirmed what I thought as well - the damn CW600 Premium does not communicate well with a computer that does not have a serial port.
What a joke - I bought a USB to serial adaptor which then I connected the null modem cable to and into the back of the receiver and nothing happened. I cannot get it to work
By all means, if you figure it out (in terms of what cables to purchase) please let me know.
U have to try various adapters with drivers and MAY get lucky...or use an older PC with serial ports...and either way U MUST have the correct comport settings
RPC i have 2003 gateway with a 9pin serial port in the back the panset 2500a took a straight thru cable it work fine for downloading but now i have a CW600 Premium i had to buy an adapter #26-264B $8.79 from radioshack and it downloaded fine everything is 9pin here no usb port sorry. thanks to everyone for the help. greg
I have 2 receiver pansat and captive work and I m not getting the Sony on 82 captive work, pant sat is getting the sony, i changed the receiver, switch , switch the lnb but no luck , can anyone help me
