Key morph is +8.?On 1st digit.
Username: Flatulant_kitty
Post Number: 205
If you don't have A/R;
So far when they roll but don't work i just add 8 to the first digit.You can tell it rolled when it starts over.Then just add 8 to the first digit.Counting a-f as 11-16.
Username: Albino_midget
Post Number: 580
will try this , is 0 ten?
Post Number: 206
0=1
Username: Redneck56
DISH - August 5
86: 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1
96: 57 F2 89 87 9E F5 EA D5 4A 83 24 B9 42 57 05 1E
Post Number: 581
thanks
Post Number: 207
Using this as example,b=3.d=5.
Post Number: 582
Thanks , this will(should) help the people!!!
Username: Top2000dogg
Post Number: 18
I put the new code but it morphs the 1st key morphs and the signal gets lost? any ideas
Post Number: 210
Worked again.Same for both providers.+8
Post Number: 211
sean akins turn off A/R.
Post Number: 19
all the autorolls are turned off and the keycode is on
Post Number: 586
sean ,you may need to use the 293T bin(with autoroll off) to get the best results for your ytmegsat or whatever.
Username: Silver1123
Mexico, DF Mexico
Post Number: 25
DN is morrphing the first key. You can fix it by adding or subtracting according to this talbe:
0=0
1=1
2=2
3=3
4=4
5=5
6=6
7=7
8=8
9=9
A=10
B=11
C=12
D=13
E=14
F=15
Just remember to first turn on the autoroll options in order for the new key to roll. Usually its a minute after you turn it on.
Change the first digit. If it is 0 thru 7, add 8. If its 8 thru F, subtract 8.
And remember to turn OFF autoroll options after changing the key, since DN is morphing every 2 minutes the first digit.
Post Number: 20
how do u do that?
Post Number: 215
I don't even turn on A/R.
If the first # is.Then.
0=8
1=9
2=a
3=b
4=c
5=d
6=e
7=f
8=0
9=1
a=2
b=3
c=4
d=5
e=6
f=7
Post Number: 21
i have this code 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1 and the 3 in the 30 changes to B from every code the first letter changes to B
Mexico, DF Mexico
Post Number: 27
If you see that the first digit on the code changes frequently, you must turn off Autoroll, since when its on, the morphing takes place
Post Number: 22
I have all the auto rolls on off its 3 right?
Mexico, DF Mexico
Post Number: 33
sean, thats right, there are 3.
just remember, if you get a black screen or a scramble signal, you turn on the autoroll. wait ans see the new key. change the first digit. turn off autoroll.
You can also input the key if you get it from the web posts without turning autoroll on, but its faster when you do it the other way.
and as soon as there is an autoroll fix, try to install it.
Good luck
Post Number: 23
the code is now morphing with the autorolls off and when the code is inputed the screen says wait for picture and the percentages go up!!
Post Number: 217
sean;i would suggest you turn off auto tp update and cc as well.If that dont work reflash the receiver with 293t.Do a factory reset first.
Post Number: 25
how do u do the auto tp update and cc?
Post Number: 218
User settings.
Post Number: 219
Turn on then turn off A/R.After turning off A/Rs Press OK and it will exit that screen.Sometimes that works.
Post Number: 26
the new keys have been dismanteled how do u stop from making the first number or letter from morphing into a B? it always happens!!!! what is reflash the receiver with 293t?
Post Number: 221
Wow.Now you just ask to much.But thanks for high-jacking.
Post Number: 27
ask too much?
Post Number: 225
Still good to go. +8
How was it no-one figured this before me???
Username: Nydas
Post Number: 3163
flatulant kitty: I had reported this key morphing 2-3 days ago. If you want to know the exact thing that is happening, it is like this.
The top bit i.e. bit 7 (in 0 origin nomenclature of 0-7 bits) of the first byte in each key is being inverted. The new BINs for a majority of receivers have a fix but eh Pansat 2500A (and its clones) fix is not out yet. Because it is so simple, I am very hopeful that it will be out soon.
Post Number: 229
Duhh!
Nah,i was first and explained in the first post of this thread perfectly for anyone who knows what i was saying.We know how to count by 16's.
Show me a thread dated before this.Maybe i just missed it.
Username: Amex
Post Number: 271
flatulant kitty, .your so full of............................... " flatulence " .
Post Number: 231
This is what i do.
This is really who i am.
This is how most would like to see me.
But thats me,i like to cause a stink.
Not blowing my horn,just couldn't see why the less brain dead than me hadn't noticed it sooner.
Username: Kingusama
Post Number: 199
new keys posted at www.ftasolutions.blogspot.com!!!
Username: Amex
Post Number: 272
"Not blowing my horn........." ............
of course not,.........
actually the "full of flatulence" part was meant as definition # 2.........
flat·u·lence(flch-lns)
n.
1. The presence of excessive gas in the digestive tract.
2. Self-importance; pomposity.
Username: Nydas
Post Number: 3166
For flatulant kitty
https://www.ecoustics.com/electronics/forum/home-video/375892.html
I had also posted elsewhere around that time and juan Cavazos got it right and explained in more details.
However, if you you want to take credit for it, I have no objection.
Post Number: 232
Mr Bill thanks for the definition.
Nalin.Guess i did miss it.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2605
"Kitty"....You amaze me with your intellegence, especially in the math department.Most wowen can't add 2+2 and balance any check book or credit cards, THIS I KNOW!
Username: Amex
Post Number: 273
your welcome flatulant kitty..........
Post Number: 233
I found that 12 credit cards weigh the same as my check book.Does that count as balancing?
Post Number: 2608
In a womens world, I guess.
Username: Sjain80
Post Number: 57
These system of 8 is working perfectly for me so far..
As soon as keys rolls, I turn my Autoroll on and let me keys roll by themselves. After they have rolled, turn the autoroll function off, and then use this system of adding or subtracting 8 from the first digit. This way you don't even have to look for keys online..it's great.. thanks a lot for telling about this...appreciate all the help and hopefully more ppl will try using it.. I been using it since yesterday and I have my TV up and running in less than 2 minutes..
Post Number: 28
that doesnt roll! it doesn't work!!
Username: Spaulding
What do you guys mean by add/ sub. 8 to the first digit? For example, what would this code change into?
Post Number: 592
key86 starts with 30 - so take the 3 and add 8 to it-- 4,5,6,7,8,9,a,b-now that it has been advanced 8 increments-key86 will now start with BO.
key96 57-- add 8 to the 5 --6,7,8,9,a,b,c,d.
key 96 will be D7 now
if a key starts with F1 then add 8 --0,1,2,3,4,5,6,7-- then it would then be 71
you can use the list posted by F.Kitty-above
Username: Spaulding
thanks Albino!!!
