12w7 not very loud...
Username: Allstar71
Jefferson, Ga
Post Number: 38
I have a 12w7 in a ported box 1.75ft^2 @32hz. I am pushing it with an orion 1200d. so at 3ohms its prob getting 500-600w. it just doesnt seem loud compared to other setups I have had.I can turn the gain up and it is closer to where I think it should be but it is distorting? do I need to suck it up and buy a new amp?
Username: Adam_s
Post Number: 1818
Yes. That amp is under powering that sub. You wont see the full potential out of it until it gets ~1000 watts.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 3898
b/c 12w7s never live up to the hype
Username: Rovin
4 10 Pioneer...
Post Number: 11916
im no expert on that sub but generally speaking thats cuft is kinda small for a 12" ,typical 12" is normally in a 2-2.5cuft sometimes more depending on what ur after ...but i suspect ur box maybe the problem here .....
Username: Insearchofbass
Post Number: 6109
what type of vehicle is it in
SOUND SPLINTER RL-S ON...
Post Number: 14702
the 12w7 likes bigger box than its recomendation. especailly if you are gonna under power it like that.
Username: Allstar71
Jefferson, Ga
Post Number: 39
Its in a toyota celica...well I had a bigger box designed...until I posted on here and was told that it needed to be smaller...would it be a good idea to get another 1200d and bridge them? Or should I buy a new amp?
Post Number: 14707
just get a new amp. my friend put a kicker zx1500.1 on that thing and it sounds awesome. the zx1500.1 does 1500wrms at 2 ohms so it will still put out good power at 3ohms.
Username: Denali_on_22s
Im just light up my......
Post Number: 2584
Hop on an HO output box by JL. Supposed to make that thing KNOCK.
Username: Allstar71
Jefferson, Ga
Post Number: 40
would but that box is really big... dont want to lose all my space...and I dont think that I would be able to close the hatch...I have a false floor that my amps are under...
Username: Carguy
Post Number: 6387
David, it's all in the box design with 12W7.
And yes, the HO box is quite big. For everyday use, I'd recommand 10W7 in a HO box. That sub with your amp should work well.
Username: Heavyhitterbass
Genoa, Il Usa
I would get a Hifonix Brutus 2000w class d amp it's around 600 bucks takes a beating and hits hard. make sure you have a cap.,at least 4 guage wire, and get the right box custom made for your car. also if you are using a factory head unit it will greatly decrease the performance of the sub and amp...you need a good min 4v output headunit also if you want to keep the factory unit there are kits out there that amplify the output voltage.
Username: Matt12490
California USA
Post Number: 2597
^disregaurd
Username: Trey4sports
Post Number: 1590
ohh god, noob advice
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 297
Username: Blainew
Post Number: 2538
^thats not really THAT bad of advice guys.....
im sure that amp is sweet joseph, but you can get a better amp for a better price for the W7, also you dont really need a cap....
Genoa, Il Usa
well the amp is very efficient and all but I have it on a 2 farad cap anyway. I wasn't really a hifonix fan whatsoever but I was pleased with the brutus 2000w I'm sure there are cheaper amps out there too..ie ebay and whatever...i'm just trying to help.
Username: Blainew
Post Number: 2539
elp is always appreciated.
people on this forum are not really fans of capacitiors, just so ya know...
also you will be introduced to many brands of amps that you have never heard of before
but everyone is a noob at one point on ecoustics!
Username: Blainew
Post Number: 2540
even trey jack and matt were once noobs!!!
Username: Allstar71
Jefferson, Ga
Post Number: 41
ok so, the only advise I have gotten so far is a Hifonix Brutus and a kicker zx1500.1
Is my best bet to go with the jl 1000/1
I have heard a 12w7 on an jl 500/1 and it was A LOT louder than my setup...
before this sub I had a re xxx which the tensils on the hot side broke.
So Basically here are my options.
1.) Get a new amp for the W7 ($600 ish)
2.) Get the xxx reconed (have a quote from fi audio to do the recone.)($180 after shipping)
3.) get another 1200d and bridge them together. ($150 used on e-bay)
here is the box I built...its actually 2.15 ft^3 tuned to approx 31.25hz
box is made of mdf with an oak veneer. My dad owns a millwork company so this was just some scrap wood.
Username: Carguy
Post Number: 6390
I'd get JL/1000 amp for your 12W7 sub, end of story/problem.
You have a quality sub, so purchase an amp that's of equal quality, not less (Hifonics).
Username: Djb0501
Post Number: 22
A 500/1 will be underpowering slightly but it will still sound decent, although the 500/1 is better suited to the 10w7, the 1000/1 more for the 12 and 13. If I were you, i'd get a 1000/1 and if you have the space, you could go slightly bigger on the box.
Username: Splmonster
C-Town, OH USA
Post Number: 1384
wat kinda wood that box made outta david?
Username: Blainew
Post Number: 2542
if your sub is getting 600 watts, and you heard the same sub on a 500/1 get louder, then it is your box.....
Username: Allstar71
Jefferson, Ga
Post Number: 42
The box is constructed of mdf with an oak veneer. My dad owns a woodshop and this was some scrap we were not using...
Username: Allstar71
Jefferson, Ga
Post Number: 43
The box is built exactly to the drawing above. As I said before my dad owns a woodshop and I had a professional build the box. There isn't a 1/32" difference from the above drawing. If someone could check the tuning that would be awesome.
I do think that it is the amp. I do not know for sure how much power the sub is getting or even how to measure the output of the amp.
If I turn the gain up it gets loud but starts to distort.
Username: Patrick_ortiz
San antonio, Tx Usa
Post Number: 19
well i dont really like jl myself, everyone else loves them so they must be pretty good, the thing is people say theyre spl subs, but i dont really hear them that way.
buy another amp, also make sure that your wiring is correct, because it sounds maybe that your ohms are off
San antonio, Tx Usa
Post Number: 20
is your amp stable at three ohms?????
San antonio, Tx Usa
Post Number: 21
get a hifonics 1606 brutus, mono block, at 2 ohms you would get about 1100 watts maybe, on ebay brand new they run about 230 - 250
Username: Allstar71
Jefferson, Ga
Post Number: 44
the amp is stable down to 1 ohm. The sub is a single voice coil. So I'm going to disregard those two posts...
Username: Rovin
4 10 Pioneer...
Post Number: 11932
'''I'd get JL/1000 amp for your 12W7 sub, end of story/problem.
You have a quality sub, so purchase an amp that's of equal quality, not less (Hifonics).'''
i agree - stop beating around in the bush
end of thread .....
Username: Skibum12189
Cleveland
Post Number: 1305
^^^ either a 1000/1 or a 500/1
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 992
Project Pat the W7 are sql sub not spl subs. Two don't go with hifonics. I agree with isaac\rovin JL 1000\1 end of story.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4847
is that wood MDF? looks like plywood to me
Cleveland
Post Number: 1310
"The box is constructed of mdf with an oak veneer. My dad owns a woodshop and this was some scrap we were not using..."
