Need some amp advice
Username: Drant19
i got a set of cdt 6.5 component and 6.5 mid range. they can take 120rms and was just trying to find an amp that would rock these speakers.. my budget is about 300 and was lookin at the kicker zx650 or phoenix gold 8.0;4..
anyone know if that PG is a good solid amp?
Username: Caliloon
Moreno valley, CA Us
i need help in connecting my sub to my amp i blew 2 subs because i connect it wrong i have a performance technic 2000 watts digital amp ired to a 12 l7 2ohms whats the best way to connect it with out blowing another sub?
Username: Drant19
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DV C%5F2%2Dohm%5Fmono
use that to help
Username: Soulja_yg
I have three 12's that are ma audio subwoofers that are 1200 watt what size amp do i need?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4829
Damn! i'm going to start with Abarca: Man if you could get the kicker, then grat, but that PG is good. Kicker is better.
Larion, post rms ratings of those subs and their voice coil config.
Username: Caliloon
i have 2 kicker L7's running on a 2000 watt amp how should i wire them? at 4 ohms 2 ohms or 1 ohm
Username: Juliob
Post Number: 4846
Bryant, are they DVC 4 ohm or DVC 2 ohm. Also what amp do you have. You should upgrade your electrical system
