Pansat 2700A scanning issue!
Username: Adama
Hey guys,
I can't get any channel!although I've downloaded the new files into my receiver(2700-X-87BL_070731_B75_205_api) quality stays 0!! I tried to do blind scan, but still I can't any channel at all!!
Any help will be greatly appreciated!!
Username: Donnie1973
Post Number: 637
Make sure it is connected right. Sat in is the top right connector. I guess you power cycled it?
I noticed that you have to set up the antanna settings all over again. Verify they are correct. Antenna type and disecq
Username: Tgyoung1
Illinois U.s.a.
I downloaded the new file 205 no problem..takes time for it to find picture then comes on..
Post Number: 638
She has "0" quality though
Username: Lklives
Post Number: 10709
Adam...U need to do the B75 boot upgrade first..
go to http://www.totalfta.com/showthread.php?t=44182
Username: Adama
I'll try to do so now... Thanks all for your help
Username: Adama
That fixed the segnal issue! now I do have segnal, but I get this message on the screen" bad scrabled or bad channel" on all channles!although, I've entered the latest key!
sorry guys! any advise what to do next??
Username: Adama
Thanks sooooooooooooooo much all! everything works just fine now! I just needed to read a little more!
LK- Much appreciated!
Best of luck
Adam
Username: Lklives
Post Number: 10741
congrats Adam...that link above from totalfta.com has helped many with uploading the B75 boot file and upgrade...the posters own way of doing the upgrade works for those who have difficulty doing it the way per the original instructions..
After the b75 upgrade, Now U upload the latest 205 bin with Working autoroll and U won't have to change keys manually..they will autoroll...it is working..
Username: Adama
LK,
Sounds good. many thanks for this info!
I was wondering If you know somebody in LA that can move my Dish for me? I'm moving out by the end of this month!
Thanks
adam
Username: Amt
Post Number: 29
adam i am having same problem can you please help me out
