Silver Member Username: Flatulant_kittyPost Number: 205 Registered: Jul-06 | If you don't have A/R; So far when they roll but don't work i just add 8 to the first digit.You can tell it rolled when it starts over.Then just add 8 to the first digit.Counting a-f as 11-16. |
Silver Member Username: Albino_midgetPost Number: 580 Registered: Jul-06 | will try this , is 0 ten? |
Silver Member Username: Flatulant_kittyPost Number: 206 Registered: Jul-06 | 0=1 |
New member Username: Redneck56Post Number: 1 Registered: Jun-07 | DISH - August 5 86: 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1 96: 57 F2 89 87 9E F5 EA D5 4A 83 24 B9 42 57 05 1E |
Silver Member Username: Albino_midgetPost Number: 581 Registered: Jul-06 | thanks |
Silver Member Username: Flatulant_kittyPost Number: 207 Registered: Jul-06 | 86: 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1 96: 57 F2 89 87 9E F5 EA D5 4A 83 24 B9 42 57 05 1E Using this as example,b=3.d=5. |
Silver Member Username: Albino_midgetPost Number: 582 Registered: Jul-06 | Thanks , this will(should) help the people!!! |
Bronze Member Username: Top2000doggPost Number: 18 Registered: Jul-07 | I put the new code but it morphs the 1st key morphs and the signal gets lost? any ideas |
Silver Member Username: Flatulant_kittyPost Number: 210 Registered: Jul-06 | Worked again.Same for both providers.+8 |
Silver Member Username: Flatulant_kittyPost Number: 211 Registered: Jul-06 | sean akins turn off A/R. |
Bronze Member Username: Top2000doggPost Number: 19 Registered: Jul-07 | all the autorolls are turned off and the keycode is on |
Silver Member Username: Albino_midgetPost Number: 586 Registered: Jul-06 | sean ,you may need to use the 293T bin(with autoroll off) to get the best results for your ytmegsat or whatever. |
Bronze Member Username: Silver1123Mexico, DF Mexico Post Number: 25 Registered: Jul-07 | DN is morrphing the first key. You can fix it by adding or subtracting according to this talbe: 0=0 1=1 2=2 3=3 4=4 5=5 6=6 7=7 8=8 9=9 A=10 B=11 C=12 D=13 E=14 F=15 Just remember to first turn on the autoroll options in order for the new key to roll. Usually its a minute after you turn it on. Change the first digit. If it is 0 thru 7, add 8. If its 8 thru F, subtract 8. And remember to turn OFF autoroll options after changing the key, since DN is morphing every 2 minutes the first digit. |
Bronze Member Username: Top2000doggPost Number: 20 Registered: Jul-07 | how do u do that? |
Silver Member Username: Flatulant_kittyPost Number: 215 Registered: Jul-06 | I don't even turn on A/R. If the first # is.Then. 0=8 1=9 2=a 3=b 4=c 5=d 6=e 7=f 8=0 9=1 a=2 b=3 c=4 d=5 e=6 f=7 |
Bronze Member Username: Top2000doggPost Number: 21 Registered: Jul-07 | i have this code 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1 and the 3 in the 30 changes to B from every code the first letter changes to B |
Bronze Member Username: Silver1123Mexico, DF Mexico Post Number: 27 Registered: Jul-07 | If you see that the first digit on the code changes frequently, you must turn off Autoroll, since when its on, the morphing takes place |
Bronze Member Username: Top2000doggPost Number: 22 Registered: Jul-07 | I have all the auto rolls on off its 3 right? |
Bronze Member Username: Silver1123Mexico, DF Mexico Post Number: 33 Registered: Jul-07 | sean, thats right, there are 3. just remember, if you get a black screen or a scramble signal, you turn on the autoroll. wait ans see the new key. change the first digit. turn off autoroll. You can also input the key if you get it from the web posts without turning autoroll on, but its faster when you do it the other way. and as soon as there is an autoroll fix, try to install it. Good luck |
Bronze Member Username: Top2000doggPost Number: 23 Registered: Jul-07 | the code is now morphing with the autorolls off and when the code is inputed the screen says wait for picture and the percentages go up!! |
Silver Member Username: Flatulant_kittyPost Number: 217 Registered: Jul-06 | sean;i would suggest you turn off auto tp update and cc as well.If that dont work reflash the receiver with 293t.Do a factory reset first. |
Bronze Member Username: Top2000doggPost Number: 25 Registered: Jul-07 | how do u do the auto tp update and cc? |
Silver Member Username: Flatulant_kittyPost Number: 218 Registered: Jul-06 | User settings. |
Silver Member Username: Flatulant_kittyPost Number: 219 Registered: Jul-06 | Turn on then turn off A/R.After turning off A/Rs Press OK and it will exit that screen.Sometimes that works. |
Bronze Member Username: Top2000doggPost Number: 26 Registered: Jul-07 | the new keys have been dismanteled how do u stop from making the first number or letter from morphing into a B? it always happens!!!! what is reflash the receiver with 293t? |
Silver Member Username: Flatulant_kittyPost Number: 221 Registered: Jul-06 | Wow.Now you just ask to much.But thanks for high-jacking. |
Bronze Member Username: Top2000doggPost Number: 27 Registered: Jul-07 | ask too much? |
Silver Member Username: Flatulant_kittyPost Number: 225 Registered: Jul-06 | Still good to go. +8 How was it no-one figured this before me??? |
Gold Member Username: NydasPost Number: 3163 Registered: Jun-06 | flatulant kitty: I had reported this key morphing 2-3 days ago. If you want to know the exact thing that is happening, it is like this. The top bit i.e. bit 7 (in 0 origin nomenclature of 0-7 bits) of the first byte in each key is being inverted. The new BINs for a majority of receivers have a fix but eh Pansat 2500A (and its clones) fix is not out yet. Because it is so simple, I am very hopeful that it will be out soon. |
Silver Member Username: Flatulant_kittyPost Number: 229 Registered: Jul-06 | Duhh! Nah,i was first and explained in the first post of this thread perfectly for anyone who knows what i was saying.We know how to count by 16's. Show me a thread dated before this.Maybe i just missed it. |
Silver Member Username: AmexPost Number: 271 Registered: Nov-06 | flatulant kitty, .your so full of............................... " flatulence " . . |
Silver Member Username: Flatulant_kittyPost Number: 231 Registered: Jul-06 | This is what i do. This is really who i am. This is how most would like to see me. But thats me,i like to cause a stink. Not blowing my horn,just couldn't see why the less brain dead than me hadn't noticed it sooner. |
Silver Member Username: KingusamaPost Number: 199 Registered: May-06 | new keys posted at |
Silver Member Username: AmexPost Number: 272 Registered: Nov-06 | "Not blowing my horn........." ............ of course not,......... actually the "full of flatulence" part was meant as definition # 2......... flat·u·lence(flch-lns) n. 1. The presence of excessive gas in the digestive tract. 2. Self-importance; pomposity. . |
Gold Member Username: NydasPost Number: 3166 Registered: Jun-06 | For flatulant kitty https://www.ecoustics.com/electronics/forum/home-video/375892.html I had also posted elsewhere around that time and juan Cavazos got it right and explained in more details. However, if you you want to take credit for it, I have no objection. |
Silver Member Username: Flatulant_kittyPost Number: 232 Registered: Jul-06 | Mr Bill thanks for the definition. Nalin.Guess i did miss it. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2605 Registered: Nov-06 | "Kitty"....You amaze me with your intellegence, especially in the math department.Most wowen can't add 2+2 and balance any check book or credit cards, THIS I KNOW! |
Silver Member Username: AmexPost Number: 273 Registered: Nov-06 | your welcome flatulant kitty.......... . |
Silver Member Username: Flatulant_kittyPost Number: 233 Registered: Jul-06 | I found that 12 credit cards weigh the same as my check book.Does that count as balancing? |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2608 Registered: Nov-06 | In a womens world, I guess. |
Bronze Member Username: Sjain80Post Number: 57 Registered: Jun-06 | These system of 8 is working perfectly for me so far.. As soon as keys rolls, I turn my Autoroll on and let me keys roll by themselves. After they have rolled, turn the autoroll function off, and then use this system of adding or subtracting 8 from the first digit. This way you don't even have to look for keys online..it's great.. thanks a lot for telling about this...appreciate all the help and hopefully more ppl will try using it.. I been using it since yesterday and I have my TV up and running in less than 2 minutes.. |
Bronze Member Username: Top2000doggPost Number: 28 Registered: Jul-07 | that doesnt roll! it doesn't work!! |
New member Username: SpauldingPost Number: 3 Registered: Aug-07 | What do you guys mean by add/ sub. 8 to the first digit? For example, what would this code change into? 86: 30 9A CF B9 C5 07 45 24 8C 5C B3 C4 50 33 60 C1 96: 57 F2 89 87 9E F5 EA D5 4A 83 24 B9 42 57 05 1E |
Silver Member Username: Albino_midgetPost Number: 592 Registered: Jul-06 | key86 starts with 30 - so take the 3 and add 8 to it-- 4,5,6,7,8,9,a,b-now that it has been advanced 8 increments-key86 will now start with BO. key96 57-- add 8 to the 5 --6,7,8,9,a,b,c,d. key 96 will be D7 now if a key starts with F1 then add 8 --0,1,2,3,4,5,6,7-- then it would then be 71 you can use the list posted by F.Kitty-above |
New member Username: SpauldingPost Number: 4 Registered: Aug-07 | thanks Albino!!! |
