Is it possible to wire a 1 ohm stable amp to a dual 1 ohm sub and have have a 1 ohm load?????
Username: Patrick_ortiz
San antonio, Tx Usa
Post Number: 17
NO right? my dual 1 ohm solo x CANNOT be wired to a 1 ohm load. especially not to a 1 ohm and higher amp??? if somone were to follow the "Dual amp config" in the kicker manual, but wire that only to one amp, what load would it be at, .5 right????? AM I RIGHt IN SAYING THAT A DUAL 1 OHM SUB CAN ONLY BE WIRED AT .5 or 2 OHMS RIGHT?!?!?!?!?!?
I am asking this because a local install place did this and blew my brand new amp, and are not taking responsiblity!!!
Username: Sqhoe
Huntington, IN USA
Post Number: 37
That is correct. If it is dual 1 ohm, those are the only ways to wire it.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4836
why didn't you ask first?
San antonio, Tx Usa
Post Number: 18
i figured a place like that would know this stuff especially, when i told them several times it was a dual one ohm model.
I am starting a lawsuit, against this place and i will post pictures to get everyones opinion, on this matter.
I appreciate your help
