Mounting the amp
Username: Slugz
Detroit, MI USA
is it ok for my amp to be mounted right on my subwoofer box?
Username: Thed42
Post Number: 74
it is ok, but not optimal. You may want to think about mounting on your rear deck or under a seat. On the box is ametuer stuff.
Username: Carguy
Post Number: 6400
Amps shouldn't be mounted on the sub box. Not only isn't professional, but it'll also cause damage to the amp over time.
It is also very convenient for crooks to steal the whole thing.
Do it right from the start.
Username: Nd4spd18
Southeast PA
Post Number: 3154
Do not mount electronic equipment on a subwoofer box
Username: Wojopro
Summerville, SC
Post Number: 277
You can, As long as the bracing in the box is built well... But like the others said it is not recommended.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4840
create an amp rack.
