Nagravision2
Username: Hienton2
I bought a second hand pansat2500A. It has only
nagravion1 in parental setup . How to have nagravision2? please help
Username: Lklives
Post Number: 10778
upload a newer bin
Username: Nydas
Post Number: 3162
tomD: You will find that this one has a very old BIN. You should load a 293T BIN. You will still have to do manual key updates till a newer 294T comes out.
G to one of these sites and get the BIN, the uploader (BL updater 1.4) and instructions. You will also need a RS232 DB9 F/F cable.
[link removed]
Mostly look for the T version in the Fortec Ultra or in the Pantec sections. If you are 100% sure that yours is a genuine Pansat 2500A, you may use BIN 293 from the Pansat 2500A file sections of the above sites, and from
http://www.future-fta.info
You may have to register - always register for free . Currently there is lot of free sites to go to.
Username: Hienton2
Thank you Nalin Nyda and LK.
I go to search now.
Username: Lklives
Post Number: 10784
here ya go...all the Pansat files and loaders...just remove the * in the link below...U must register also...free site...
http://www.dsscommunity.c*om/forums/viewforum.php?f=31
