Username: Audio_newb Post Number: 33 Registered: Jul-06
Sunday, August 05, 2007 - 20:15 GMT I recently fixed a box for my friends 2 15s (sealed it up and other stuff) I hooked them up to the amp, and to my suprise one was hitting alot harder than the other one was. Is a voice coil out? or could there be something else that i dont know about. Thanks in advance
Username: Thumpinwith8s 2 RE8s,PG Xenon 400.1,
New Numbers ...
Post Number: 582 Registered: Jun-07
Sunday, August 05, 2007 - 23:38 GMT need a little more info...what subs what vc, what amp, etc
Username: Audio_newb Post Number: 34 Registered: Jul-06
Monday, August 06, 2007 - 02:28 GMT Ok just got home from work. They are Memphis Power Reference 15s They are Dual 4 ohm and its an MA Audio 1000w Monoblock (overpowered i know but its the only amp i got) If i can find out whats wrong with them i may use them myself, he only wants 100 dollars for em.
Username: Audio_newb Post Number: 35 Registered: Jul-06
Wednesday, August 08, 2007 - 03:39 GMT Any Ideas?
Username: Jkidder Spring hill,
Florida
Usa
Post Number: 1464 Registered: Nov-05
Wednesday, August 08, 2007 - 04:03 GMT could be tons of things. so hard to tell over the internet. take a look at the coils. hook it up to a dmm. push on dustcap, make sure its not locked up. could be so many things
Username: Crayola0 Future 15 Wanger!!,
Wisconsin
Post Number: 2042 Registered: Jun-06
Wednesday, August 08, 2007 - 04:05 GMT hey tyler where are u from??
Username: Audio_newb Post Number: 36 Registered: Jul-06
Wednesday, August 08, 2007 - 04:08 GMT Tennessee, JK the sub isnt locked up, i think its not taking enough power, the voice coils seem in good shape they dont smell burnt. The only type of machine is an ohm meter would i need to use that would that help. I just wish i could get em workin
Wisconsin
Post Number: 2043 Registered: Jun-06
Wednesday, August 08, 2007 - 04:09 GMT alright nvm
Username: Audio_newb Post Number: 38 Registered: Jul-06
Wednesday, August 08, 2007 - 04:25 GMT Ok i think i found the problem. I run a meter to it tested all voice coils on the first and the second and the one that isnt hitting right one of the voice coils showed no activity. IS there any wya to fix this or is just a dead sub?
Username: Yukhui Myrtle Beach,
South Carolina
Post Number: 593 Registered: Jan-06
Wednesday, August 08, 2007 - 04:42 GMT check the leads are still intact.
Username: Audio_newb Post Number: 39 Registered: Jul-06
Wednesday, August 08, 2007 - 04:48 GMT They are but im not sure if they are under the dust ca. They are connected snugly on the posts.
Florida
Usa
Post Number: 1466 Registered: Nov-05
Wednesday, August 08, 2007 - 04:50 GMT what sub?
Username: Audio_newb Post Number: 40 Registered: Jul-06
Wednesday, August 08, 2007 - 04:53 GMT The memphis with the bad VC, could i wire it to just run off of one. I know its not good for them but would it work. Wire the one sub that works to equal 4ohm. So it equals the other? or is there anyway to fix the VC?
Username: Splfreak Post Number: 6 Registered: Jul-07
Wednesday, August 08, 2007 - 05:20 GMT not gunna work
