Username: Alexb2191 Post Number: 4 Registered: Aug-07
Monday, August 06, 2007 - 23:50 GMT when you say "bridged wire" do you use speaker wire and connect + with - or do you just use regular automotive wire?
Username: Thumpinwith8s 2 RE8s,PG Xenon 400.1,
New Numbers ...
Post Number: 599 Registered: Jun-07
Monday, August 06, 2007 - 23:55 GMT bridged means wire running from one channels positive to the speakers, and anothe wire from the other channels negative to the speakers....and its usually marked on the amp which ones you use to bridge the amp. and you use speaker wire.
Username: Alexb2191 Post Number: 6 Registered: Aug-07
Tuesday, August 07, 2007 - 00:04 GMT i have a one sub thats quad 2 ohms and it wants me to bridge the wires in the sub. like http://www.audiobahn.com/Audiobahn06/images/tech/wiring/immortalsubs.pdf p. 40....2nd diagram
Username: _sb_ Post Number: 3 Registered: Aug-07
Tuesday, August 07, 2007 - 21:42 GMT mabye u shouldn't buy 0 gauge wire
