Tuning Help!!!
Username: Kaprese
Walstonburg, NC USA
Post Number: 336
Alright I am starting on another box for 2 12's in a common chamber and I'am going to slot-port what would be a good tuning freq.? I like alot of lows, and still want that bit of SPL to be there.I listen to all hip-hop of course so what would be a good tuning?
any ideas or suggestions I really need it today
Username: Kaprese
Walstonburg, NC USA
Post Number: 337
all I am asking is for a good tuning freq. ? is that so hard .............
Username: Ctmike
Ct.
Post Number: 4929
try posting what subs you have and you might get some good recommendations.
and why not try waiting more than 13min. before getting upset that there's no response, not many people post this early.
Username: Kaprese
Walstonburg, NC USA
Post Number: 341
I was just joking mike......I was just ready to get started on my box but I already have some ideas
Username: Mgbcs
Maple Grove, Minnesota
Post Number: 1497
We still need to know the subs...
Username: Kaprese
Walstonburg, NC USA
Post Number: 342
they are some cheap Pioneer TSW301R subs they are going in my brother car (young guy)they are about 150rms a piece so what would be a good tuning and does giving the subs there own "chamber" make a differnce ?
Username: Rovin
4 10 Pioneer...
Post Number: 11923
i would say tune into mids 30s even upper 30s
separte chambers IMO sounds a bit cleaner than single ...but single = more output .....
Username: Kaprese
Walstonburg, NC USA
Post Number: 343
alright you say more output are you talking noticeably output.... like 2-3db ?
Username: Kaprese
Walstonburg, NC USA
Post Number: 344
I think I am going to tune the box for 32hz then I am thinking I can get good lows and still some SPL
Username: Rovin
4 10 Pioneer...
Post Number: 11925
well i didnt have a meter when 1 once tested my 2 type R in single & separte boxes just to see for myself , but to my ears the single sounded a bit louder
but i wouldnt tune 32hz since thats more SQ - IMO around 35\36 = more SQL ....i never used that model b4 but DONT go by rec specs for pioneer subs ...if unsure always use the max cuft they give u so u get more deeper bass .....
Username: Kaprese
Walstonburg, NC USA
Post Number: 345
but would tuning to 35/36 still give me that low bass extension.....I just love low bass
Username: Kaprese
Walstonburg, NC USA
Post Number: 346
Username: Mendonmafia
Post Number: 382
prted boxes lose out on alot of low end extension due to the lack of suspension below the tuning frequency. there is not enough air in the port to reinforce the bass output and therefore the output drops drasticly. if you want low end extension your gonna have to tune your box to a max of 32 hz or go sealed. boxes tuned to 32 hz or less will generally be louder at every frequency than a sealed box including at the low end.
Username: Kaprese
Walstonburg, NC USA
Post Number: 350
would I be ok at 33hz
Username: Kaprese
Walstonburg, NC USA
Post Number: 351
I am thinking if I tune to 33hz I would still get a mix of SPL and low end extension.....what you think
