LK ? for you
Username: K81
when i enter codes in nagra2 for dish the will not save and keeps sayin bad or scrambled
Username: Donnie1973
Post Number: 654
make sure they are the latest keys. If it is a pansat or fortec (you should give more info) try to turn off and back on from the back. Make sure autoroll is off.
Username: K81
Post Number: 10
auto is off pansat when i enter keys for dish what is the provider keys i typed 00 01 then under that 00
Post Number: 656
you should leave everything alone there except the keys.
keys 00: EA 4C 83 0B E0 C1 77 93 33 23 6B ED 03 E9 B2 CB Active
keys 01: 04 63 99 9E D4 1E CD CF 01 B3 A9 CD 53 C4 F0 24
Username: K81
Post Number: 12
dantetn i need to know that part this is the problem im having ty
Post Number: 659
y dont you download the new bin file as LK suggested. Soo easy, no more entering keys! And surely u have been entering keys before... right?? come on dude
Post Number: 660
menu
installation
parental control
push down
0000
nagra2
Keys 00:
enter keys 00 that I provided
push to the right on remote
keys 01 that i provided
Going off memory, I should be close enough for u. I havent had one for a while. Upgraded to VS
Username: K81
Post Number: 13
im in the states and g/f is in mexico but i got it back on ty for you help they got entered manual but took long time to take so ty
Username: Lklives
Post Number: 10793
Its easier to just upload the Pansat 2700 205 bin...the u won't have to manually input any more keys..
Username: Arshaddar
hello
l have a viewsat ultara 2000 no power anyhelp nothing
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2612
If its a clone your sol. If it's an oringinal contact VS repair for a rsm to send it for repair.
Post Number: 2613
oh, total fta has some posted fixes you can try at there site , good luck.
Username: Lklives
Post Number: 10799
How to tell a fake counterfeit Viewsat
[link removed]
Bring a unit back from the dead!! ...a copy/paste
Ok I have seen alot saying there units look dead. Here are a few things to try before sending it back to VS.
1. if it's a clone your SOL
2. reboot pc
3. reload factory file
if still no go and you have access to another working receiver then do the following:
1. Load working unit with factory file
2. Once loaded hook up serial cable to dead receiver with power from back switch to off
3. On working unit hooked up to tv do the following:
Menu-> Installation -> Reciver Upgrade
choose main software and click OK
(you will see a progress window)
4. Turn dead unit on from back switch
5. The progress bar should start to move indicating dead unit is being programed.
If it doesn't check make sure your serial null-modem cable is firmly in place to both receivers and try again.
If the above does not work then your unit is in fact dead... or has a blown fuse.
I have brought a few units back when they seemed to be dead with no front display at all, with these procedures.
