Ways to fix a dented cone???
Username: Santa_fe
Post Number: 24
buddy has a dent in one of his cones...it doesn't affect the sound quality as far as i can tell it more of an ascetic thing...any ideas on how to pop it back out??
Username: Denali_on_22s
Im just light up my......
Post Number: 2579
take it off pop it out then glue it back...
Username: Blainew
Post Number: 2535
suction......... or stick something sticky on it and pull it out...
thats the two ways i have done it
Username: Bigharv
Post Number: 270
depends how big of a dent it is, what type of material the cone is etc. take a pic and we might be able to help more.
Username: Imnothereimjustvisiting
like blaine said... suction i use tape
Username: Jtown
Post Number: 191
none of those worked for me. justin change your name, I'm the only Justin on the forum since jogle left.
Does your sub have a hole in the back?
If so, take a wooden dowel and put that in the hole and very gently push the dent out. Or use an air compressor and shoot a small amount of air into the back to pop the sucker back out.
Username: Philly306
North carolina
Post Number: 213
Uhh Justin that is jogle. look @ his username
^^^^^^^ ha ha ill change it
hows this?
Username: Kpa2727
Post Number: 499
i take no blame, but i have used hot glue for a real tight grab to pull it out.
Username: Jtown
Post Number: 192
I feel really stupid all of a sudden.....how's it hanging...jogle?
Post Number: 8
low and to the left
