New member Username: ColdchrisBattle Creek, Michigan USA Post Number: 5 Registered: Aug-07 | I jus bought a 2400D directed mono amp and have it hooked up through a 3.0 farad power acoustik capacitor, pushing 1 15" power acoustik 2ohm dual 2600 watt sub in a custom ported box. When i turn the power up the amp cuts off and flashes about 4 times then starts working again. According to the amp manual it is an over current warning. Anybody have any idea why this is happening and what i can do to stop it????? also is there a way for me to have my 2 ohm dual sub running at 1ohm so i can get the more power? thanks |
Gold Member Username: Kd7nfrMontpelier, ID United States Post Number: 1763 Registered: Apr-05 | You need to upgrade your electrical system. Start with a HO alternator. With that amp you'll probably need to get a better battery, maybe add some by the amp. |
New member Username: ColdchrisBattle Creek, Michigan USA Post Number: 6 Registered: Aug-07 | thanx jake |
Gold Member Username: 420alldaylongPost Number: 2405 Registered: Sep-06 | Do this first http://www.subwoofertools.com/forum/setgain.asp If that didn't work do this. http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1 Wire your sub this way. http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=2o hm_dvc&x=153&y=12 I hope this helps you out. |
Gold Member Username: 420alldaylongPost Number: 2406 Registered: Sep-06 | Oh yeah use the biggest gauge wire the amp will take.(Power and Ground wire) |
New member Username: ColdchrisBattle Creek, Michigan USA Post Number: 7 Registered: Aug-07 | thank you joey, i didn't realize it was so complicated setting the gain on an amp lol I'ma try these solutions as soon as it stops raining |
