TV Guide On-Screen Info and High-Def Cable Box
Username: Toro19
I have a Panasonic DMR-E85H DVD Recorder. I recently switched to high-def cable and since that time, I'm told by Panasonic that the TV guide on screen programming doesn't pass through the cable box. Does anyone know a workaround for this issue? I will not be able to use the DVD recorder as I once did if this is the case because I'll need to split the cable signal and send one to the cable box and another to the DVD recorder. The DVD recorder will not be able to record anything from the cable box and one-touch recording will be useless too. Any help?
