Needing Pro HELP~~~~~~~~~
Username: Star_star
Post Number: 24
Btw Can Someone help me i was recently deled all chans THEN rescaned all chans and instered all keys and turned off auto-roll BUT............................................................................. ............................
SOMe hindi chans and Azn Chans r not even Showing up can anyoen help me PLZ PLZ plz
F.Y.I
i got
Fortec star Lifetime Ultra
I use echo 7,3,6/8
Username: Nydas
Post Number: 3129
zas : The latest BIN for the Fortec Ultra is 293T. For the last two days the autoroll portion that loads the new keys automatically, does not work. so you have to install the keys manually.
Go to the keys thread to get the keys. Keep autoroll off. Also do a Blind scan - you will get better results.
https://www.ecoustics.com/electronics/forum/home-video/259083.html
Username: Star_star
Post Number: 26
errmmm ok Keycode ON
Auto roll OFF>?
whats that do?
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2528
tells the program to use decrypting keys to open encrytion .
autoroll tells it to ignore grabbing the keys and locks the inputted keys in memory when off.
on tells it to grab and insert present keys from the stream and update when there is any change.
Username: Star_star
Post Number: 27
i see your smart =P
