Black wire from intellistart....
Username: Cswminty
Tamworth, Staffs UK
Post Number: 8
I have a black (with a faint Grey line down it) that runs from the intellistart to under the bonnet.
Only when fitting the wiring loom back into the car i am unsure as to where that wire connects to.
I have a connector that is on the fuel injector, is it that it connects too???
any help would be greatly appreciated.
Thanks
Chris.
Username: Cswminty
Tamworth, Staffs UK
Post Number: 9
i think i found it on a wiring diagram
BLACK/GRAY - RPM Input
but what would it connect to under the bonnet on a scooby??
Username: Cswminty
Tamworth, Staffs UK
Post Number: 10
i think i have found it again.....
H2/12--black/gray rpm input
This wire monitors the RPM of the vehicle during remote start sequence.
Connect this wire to the vehicle coil's negative side or the non-common fuel injector wire.
