New member Username: JerrycortesSLP, SLP Mexico Post Number: 3 Registered: Jun-07 | HI, I have a viewsat lite. it was working ok, I made a blind scan and channels appears double then I chose Factory Settings, I saw some channels, then turned off and on and it got cycled: appears only: 00.00,213,----,on,- (213 was the last channel. front buttons control and remote control do not works. I tried to load factory bin but sent error. HELP!! |
New member Username: ChuchissPost Number: 1 Registered: Aug-07 | Jerry: Hola, pudiste resolver el problema con tu VS lite? como lo resolviste? saludos |
New member Username: JerrycortesSLP, SLP Mexico Post Number: 4 Registered: Jun-07 | no, sigue igual, no acepta ni carga de BIN Factory, ni nada... esta totlamente trabado. Lei foros con la misma falla pero que aceptaban la carga de BINs... no se que hacerle. Habra algun juego de jumpers o algo interno que poder resetear? |
New member Username: ChuchissPost Number: 2 Registered: Aug-07 | Yo ya pude bajarle el factory encontrado en la pagina de VS, y lo acepta bien; es el V0271PLATINUM-VIEWSAT.PGM pero despues que intento montarle el ultimo fix regreso a lo mismo |
New member Username: ChuchissPost Number: 3 Registered: Aug-07 | Jerry: ya lo pude resolver, manda una cuenta de correo a la cual te pueda enviar los archivos necesarios. |
New member Username: JerrycortesSLP, SLP Mexico Post Number: 7 Registered: Jun-07 | JC, te mando una cuenta: gerardocortes@hotmail.com |
