Answer my own question concerning Magnum: C/P from thebroken
Team Reliable Coder
Please READ before loading 152...
Ok, I notice some people dont like to read other's experiences before loading a bin, SO, I will give you an update.
THIS BIN was never meant to be released... It was a fall through, meant to give you guys autoroll, and NO MORE than that. The code base has been through some dramatic core changes, and as a result it is COMPLETELY different from any other bin released to date. Database (FOR CHANNEL STORAGE) has been moved to the FLASH (So channel list wont disappear when you decide to go on vacation) Scanning core has been rewritten completely. Kernel is based on newer coding techniques.
I did not get a chance to convey all the details to Mikesmadd before releasing, and we were rushed to get this out before it was ready.
SO FACTORY DEFAULT BEFORE FLASHING THE FILE FACTORY DEFAULT AFTER FLASHING THE FILE
The reason is simple THE CHANNEL LIST IS NO LONGER STORED IN THE SAME LOCATION Also, before this bin you had a maximum of 3500 channels (2000 TV, 1500 Radio). NOW, there is a limit of 8000 channels (6000 TV, 2000 Radio) Channel Master WILL NOT WORK for the time being, because it does not support LZW compression, which is used in this codeset to allow for faster interaction with the FLASH, and to allow MORE data to be stored on the flash.
We will be submitting information to C-Sharp to resolve the channel list incompatibility.
People saying that it is freezing, I understand your concern, please, turn off autoroll after you have rolled the keys.
Bev users, in 153 you will have the ability to retrieve 7 day guide for BEV, with a second LNB pointed at 82. __________________
Future FTA - Blacklist's Site: [link removed] (C00LSAT and All receivers) DSS Newbies: [link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: [link removed]
Best site for DISHNET info, channels, transponders and changes etc.. [link removed] [link removed] www.filez.us/km3/keys.shtml
Magnum roll with TR v152 bin when you reset and rescan.............For those of you who are to lazy to do that try this: C&P from SatJunkie: when we have to enter the keys manually this is what I do. Rather then get up and off the couch, I go to MENU>SOFT CAM> and I change the provider name to GlobeCast and if that don't work I change it to DIGITAL+ wait for literally 5 seconds and BAM TV back on!
