Clifford eagle remote/fob question replacement
Username: Ukdirtyboy
hi all i have a clifford eagle with a two button 3 channel the code inside the remote is 3CH418ACG
i have just purchased a replacement remote which says LC 6CHAN 27-6604 REV-A and some other writeing on the chips
anyone no if i can use the replacement channel remote ? they look the same till you open them apart from one has green LED other has yellow LED
