Box Terminals???
Username: Cplaya280
Quakertown, PA USA
Post Number: 627
does anybody know where i can find terminals for my sub enclosure because mine fell apart today sumhow when i was moving the box around or is there a way to make ur own terminals for the box. thanks
Username: The_image_dynamic
San Diego
Post Number: 2540
Don't use em. Drill a hole in the box and put the wires through it and silicone it off.
Username: Cplaya280
Quakertown, PA USA
Post Number: 628
wait what do u mean cuz dont you have to put the wires into + and - terminals inorder to get the sub to work i dont understand what your saying
Username: Joebruce
15 Inch Wang...
Post Number: 1193
lol it fell aprat! but yea direct connect is the best,jus drill a hole in ur box and put the wires threw it it. but if u need terminals go to www.partsexpress.com
Username: Cplaya280
Quakertown, PA USA
Post Number: 629
i still dont understand ok drill a hole and put the wires threw the hole and then what am i connectecting the wires to since im not gonna be using terminals?
Username: Joebruce
15 Inch Wang...
Post Number: 1195
damn, jus take the wires directlly from the subs/speakers to the amp. u dont have to have terminals to do that. im not sure why ur confused,im confused on why ur confused. lol,it may be the alkahol.
Username: Cplaya280
Quakertown, PA USA
Post Number: 630
ohhhhh i get it so the wires that go into the terminals just use them to put directly into the amp i got it now
Username: Cplaya280
Quakertown, PA USA
Post Number: 631
so why is it better not to use terminals is there a main reason why or does it not really matter??
Username: Joebruce
15 Inch Wang...
Post Number: 1197
lol. supposedlly it jus gives you a better connection,instead of going from the sub/speakers to the terminals then from the terminals to the amp it just a str8 connection from the speakers to the amp.
Username: Cplaya280
Quakertown, PA USA
Post Number: 632
i guess that makes sense well thanks for the tips
