New member Username: Jordan1980Post Number: 1 Registered: Jul-07 | I pray im in the right spot for starting this thread. I need some help with a kicker system im putting in my 07 Monte carlo. I have a KX 1200.1 Kicker Amp and I recently purchased 2 12" Kicker L7's, both being at two ohms in a sealed box. I want to know if that amp will push both subs and what would be the best way to wire the subs? I also want to look into adding a capacitor to the setup. Any feedback would greatly be appreciated!! Thanks ~tj} |
Silver Member Username: Kicker101Alberta Post Number: 204 Registered: Nov-05 | http://www.rockfordfosgate.com/rftech/woofer_wizard.asp its all there bud..... ohyeah i have the same setup as you. |
Gold Member Username: LoudonPost Number: 1446 Registered: Jun-04 | yes man thats a good budget spl setup ... for sure |
Bronze Member Username: SomedonniedudePost Number: 79 Registered: May-07 | Did those L7's came in kicker brand boxes? Just wondering becouse if so that that amp will work good becouse thats a 2 ohm final impendance per sub. If there just dual 2 ohm subs than that amp might not work... |
New member Username: Jordan1980Post Number: 2 Registered: Jul-07 | The subs I have I bought brand new in the box. The enclosure isn't branded by Kicker. So your saying I'd be better off with 4ohm 12" Kicker L7's and exactly how would I go about wiring each sub? |
New member Username: Jordan1980Post Number: 3 Registered: Jul-07 | Couldn't I just run both 2ohm voice coils wired in parallel to produce a single 1ohm load? The KX 1200.1 is a one ohm amp I believe? |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1223 Registered: Nov-05 | 2 dual 4 ohm=1 or 4 ohm load 2 dual 2 ohm=2 ohm load 1 dual 4 ohm=2 ohm load 1 dual 2 ohm=1 or 4 ohm load |
Gold Member Username: Skibum12189Cleveland Post Number: 1125 Registered: Mar-06 | youd be best off returning the subs to get 2 dual 4 ohm L7s or returning the amp to get a zx1500 so you can run your current subs at 2 ohms if you run 2 dual2 ohm subs at 2 ohms off a kx1200 youll only give MAYBE 400 watts a piece |
New member Username: Jordan1980Post Number: 4 Registered: Jul-07 | I was able to return those 2 ohm subs for the 4 ohm. How do these subs need to be wired in order to reach max performance from my KX1200.1 Amp.. The amps aleady set to output a 1 ohm load correct? Also whats a good battery cap I could get? |
Bronze Member Username: B3n07Louisville, Ky USA Post Number: 62 Registered: Jul-07 | i thought that all kicker subs had selectable impendance |
Silver Member Username: ImalikSD2.5......ED9.1=Boom, New Jersey Lord Protect... Post Number: 489 Registered: May-06 |
