Gold Member Username: Safe_crackerChicago, IL US Post Number: 3138 Registered: Jan-06 | I am finally getting this sub to move... I had air movement before but NOW woohooo. I can only run it at 1/2 power (2ohm and at 14V) but it is sooo loud and the amp barely heats up. Good to know I probably have as much power as I will ever need, just need to get the aux batteries in and bring it up to 16V. Polo.. This is just a test fit, gonna make a box for it with some fans and outside ventilation. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 5623 Registered: Jul-06 | good sh1t polo....videos when yuor all done please |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3893 Registered: Jul-06 | Were those amps rated at 16volts? Because if so you're getting like 3500-4000 @ 2 Ohms(Site says 4800@2Ohms but doesn't list voltage used).That's quite a bit already for that Treo. |
Bronze Member Username: TejcurrentPost Number: 81 Registered: Apr-07 | I had one for a very short period of time, but they are 6500 at 16v. Output Power at 1% THD+N: 1 x 1697W @ 4 ohm (13.5V) 1 x 1750W @ 4 ohm (14.4V) 1 x 2905W @ 2 ohm (13.5V) 1 x 3290W @ 2 ohm (14.4V) 1 x 4082W @ 1 ohm (13.5V) 1 x 4490W @ 1 ohm (14.4V) The page lists (RMS, unknown voltage and THD): 3400W @ 4 ohm, 4800W @ 2 ohm, 6500W @ 1 ohm S/N Ratio: >80 dB Damping Factor: >350 @ 80Hz (+/-5Hz) Operating Freq. (band-width): 15Hz ~ 150Hz Dimensions: 24.53" x 11.42" x 2.56" (62.3cm x 29cm x 6.5cm) Max. DC current: 465A DC (1 ohm, 1% THD+N) Same board as: . Audiobahn A4KDN . Ground Zero GZPA 1.6000D . Lanzar OPTI 4000D I've read tests where it did more and less than 6500 @ 16v, but many say it doesn't do it at <=1%thd. Still a stout amp, and very beefy in person. |
Gold Member Username: 420alldaylongPost Number: 2349 Registered: Sep-06 | Great amp are you going to get it metered. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3141 Registered: Jan-06 | I don't know, maybe not just a daily, lol. I know the power ratings that is why I bought it, very versatile and the power keeps going up with voltage increases. Some have even ran them at 18+V even though I would never. I have my two racing dual voltage 16V batteries, external adjustable regulator and was thinking of a BatCap 8400, 16V version of course... I will run the amp 16v @2ohms for stability...Polo. |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 11857 Registered: Jul-05 | cool but big azz amp a bud of mine has this amp powering a wall of 8 10" pioneer SVC 256 model http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14522 so its being ran @ 2ohms on 13.8v current & he has 4 massive batts in the trunk but the set is quite LOUD ! ..... |
Gold Member Username: JkidderSpring hill, Florida Usa Post Number: 1210 Registered: Nov-05 | sweet setup polo. how much do those BC 8400's cost? |
Silver Member Username: DjhasanicesoundsystemVista, Ca Usa Post Number: 147 Registered: Feb-07 | so how much did you spend on that amp? and do you think it will be enough to power 2 12" RE SX? |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3899 Registered: Jul-06 | "so how much did you spend on that amp? and do you think it will be enough to power 2 12" RE SX?" Of course it will be enough to power 2 12'' SXs.Do you have the charging system for that kind of amp?I guess Polo does. |
Gold Member Username: Denali_on_22sIm just light up my...... Post Number: 2495 Registered: Feb-06 | Numbers. Now. You've kept it a secret for too long. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3150 Registered: Jan-06 | Rob, I am borderline on that, lol. This amp is a current hog, even at 2ohms. I have yet to add the aux bats so I will keep you all posted on it. hey how much do the 8400's go for, just gonna get one, 16V but I am getting a good deal with a charger also for $480 shipped. I am sorry, I have no numbers BUT I think as soon as I get it dialed in a movie will be in order! Polo.. |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 8788 Registered: Jun-06 | |
Gold Member Username: Extrmndor3Post Number: 6381 Registered: Feb-06 | good luck fittin a 8400 in yoru trunk next to yoru amp and next to your sub box |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3153 Registered: Jan-06 | LilRob, it's just like your D!ck, easy fit, lol! |
