Anyone that has experience with the 780mp
Username: Matt12490
California USA
Post Number: 2585
I'm trying to figure out how to use the AUX source and it is really making me mad. I bought my stereo mini plug cable and plugged it into the AUX jack in the back and plugged the other side into my ipod and turned it on.
The owners manual says it should recognize it as long as the AUX source is switched to on. Now to switch it on it says to use the multi control but doesn't go into ANY detail on how to do it.
Can anyone help?
Username: Andrew571
Post Number: 1066
i think the setting is the same area u change the calendar and time n such.... when the unit is off...
just a guess tho
Username: The_image_dynamic
San Diego
Post Number: 2495
Andrizzle is basically right. First turn the power off. Then press and hold the jog controller (the big silver knob) in order to get to the settings such as language. Scroll left or right until you see AUX 1. Press the jog button to turn the AUX 1 on or off. Then... press the SOURCE button and select AUX.
Username: Matt12490
California USA
Post Number: 2587
Thank you it worked! You guys are awesome.
Username: Andrew571
Post Number: 1071
no problamo mis amigo
